A/D converter problem
Results 1 to 6 of 6
Threaded View
    Default A/D converter problem
    Hi Everyone,
    I am having difficulty using Pic’s onboard A/D converter. Can someone give an advise please.
    I want to measure the voltage across automotive battery when the car is running. When the vehicle is stationary the power to the PIC is off (to prolong the battery quiescent time). So I assembled a simple test circuit on the bench. The problem is that when the power to the Pic is off it still could be powered if the potentiometer is in high(5v) position. But the one that worries me the most is if the potentiometer is in midway( I read around 1.3v at Vdd with Pic’s 5v disconnected) position the Pic locks up and I have to reconnect the power several times to reset it and make it go again.
    I really don’t want to use external brown out circuitry if possible. May be you’ve come across the same problem. If yes please share your experience.
  1. Replies: 9
    Last Post: - 31st July 2008, 08:56
  2. A/D conversion problem in 18F2520, 2523, 2550 etc.
    By selimkara in forum mel PIC BASIC Pro
    Last Post: - 10th March 2008, 16:26
  3. A/D converter fails?
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 13th February 2006, 18:57
  4. A/D converter with pic16f84, i need a help
    By micro in forum General
    Last Post: - 13th December 2005, 21:17
  5. help with pic16f870 a/d converter
    By cammo in forum mel PIC BASIC
    Last Post: - 22nd March 2005, 05:16
