16f88 problems
Results 1 to 18 of 18
Thread: 16f88 problems
    Can we see your code?
    Nov 2007
    Default lingering questions
    Unfortunately I don't have it with me. When I get home I will put it up.
    I'm curious if there are any events during startup which could influence my code to jump past the first loop that is waiting for the buttonpress.
    Also my question about ansel = 0 and whether that makes the analog pins digital still stands.
    Also the fixes I tried with power supply, and the questions about the MCLR pin are still bothering me.
    As I say, I don't actually think it's the code that is the problem. I feel it's more of an odd hardware issue with the 16f88. I realize this is a pbp forum, but other people have had trouble with the 16f88 that are similar to mine, and I thought some people here may have already faced this one down.
    My code size is small enough for the chip as well. Something like 500 words.
    I do not have the data sheet in front of me but I do not think ansel=0 is the way to go.
    Check the data sheet and read this.
    MCLR is not a problem when made an input. The only concern is tothe external parts if any being able to handle the higher voltage. A well placed diode will normally solve any problems.
    Quote Originally Posted by mikey11 View Post
    Hi Mikey11,
    The buttonpress . . . does it go high or low when pressed? What is its power off status? Any chance your PIC is seeing a buttonpress condition there ? Can you accept a delay at startup before initialising your TRIS registers ?
    USA - Arizona
    You still need to post the code. It truly sounds like you have something not properly initialized. If nothing else the code will show which pins are in use and what functions those pins share.
    Make sure you have CMCON = 7, as well as ANSEL = 0.
    So why should the OP post the code? We were told that is not the problem.
    USA - Arizona
    Oh let's see...
    If the code does not properly initialize the HW, the HW does not behave as expected. Such is the lifecycle of embedded programming. But I see, that was you point from the beginning ...
    I do not have the data sheet in front of me but I do not think ansel=0 is the way to go.Check the data sheet and read this. http://www.picbasic.co.uk/forum/showthread.php?t=561
    Oh well, hopefully he takes the advice. Its all given in good faith (and free).
    Nov 2007
    Default code portion
    hi guys, sorry about the wait. I work over 1000km away from my home, and don't get many opportunities to be there at the moment.
    Here is the code up to and including the first loop where it waits for a button press.
    <code>
    Include "modedefs.bas"
    CMCON=7 'allows you to use pins as digital rather than analog
    ADCON1 = %00000111 ' Disable A/D converter
    ANSEL=0 'allows you to use pins as digital rather than analog
    @ DEVICE PIC16F88, INTRC_OSC_NOCLKOUT, MCLR_OFF, WDT_OFF, LVP_OFF, PWRT_ON, PROTECT_OFF, BOD_OFF
    DEFINE OSC 8
    OSCCON = %01110000 ' INTRC = 8MHz
    'declare inputs and outputs appropriately
    TRISA = %00111100 ' a.5 is INPUT only
    TRISB = %11100100
    'define variables
    mscounter var word
    secondcounter var word
    minutecounter var word
    loopvar var word
    'INPUTS First Name them by pin
    rwire var portb.2
    bwire var portb.1
    mswitch var portb.0
    playmode var porta.2
    testmode var porta.3
    startbutton var portb.5
    'eventually the mode switch it will be a three position switch, and a.4 will be another input.
    'OUTPUTS, Name them
    solenoid var portb.3
    modeled var porta.1
    flashingled var porta.0
    buzzer var portb.4
    'Now perform the initial wait until the start switch is pressed
    modeled = 1
    solenoid = 0
    pause 2000
    startloop:
    flashingled = 1
    pause 50
    if startbutton = 1 then goto checkvalues
    flashingled = 0
    pause 50
    goto startloop
    </code>
    As I've indicated before, the rest of the code works fine, and it eventually leads back to this first loop. On the first execution, it skips this loop, and proceeds to the next section of code. When the program completes it comes back to startloop and then everything runs fine. I just need it to engage this first loop the first time.
    I do not have an absolutely clear understanding of the ANSEL and CMCON commands. I've read about them and think I'm using them right.
    It's possible I shouldn't even be using the ADCON command. I don't know though.
    If anyone has great ideas I'm still very much interested in sorting this out.
    Cheers, Mike
  1. Code works on 16F84A but not on 16F88?
    By pharaohamps in forum mel PIC BASIC Pro
    Last Post: - 6th November 2009, 19:29
  2. Can't get a 16F88 to do anything.
    By ccowley in forum General
    Last Post: - 26th August 2008, 00:42
  3. 16F88 RA6 and RA7 troubles
    By gandora in forum mel PIC BASIC Pro
    Last Post: - 3rd August 2007, 03:57
  4. 16f88 help
    By ccsparky in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2004, 18:50
  5. 4 line LCD with 16F88
    By anj in forum mel PIC BASIC Pro
    Last Post: - 7th February 2004, 10:06
