keypad?
Results 1 to 3 of 3
Thread: keypad?
    france
    Default keypad?
    Hello
    I have a problem with this program for managing a keypad.
    when I press a key such as 1, it displays "1111" when I
    supported once the?
    thank you
    Quote Originally Posted by jonas2 View Post
    Hello
    supported once the?
    thank you
    Hi Jonas2,
    I see 2 things I question:
    1. IF i = 4 THEN GOTO confirm ' code complet ? oui confirme
    0 to 3 so it should be complete @ 3
    2. You are exiting a for next loop in a rude fashion. I would tell the loop row = 3 and then gosub. IMHO
    Like so
    FOR row = 0 TO 3                     ' 4 rows in keypad
                PORTB = 0                            ' All output-pins low
                TRISB = (DCD row) ^ $ff              ' Set one row pin to output
                col = PORTB >> 4                     ' Read columns
                IF col != $f THEN row = 3              ' If any key  own, exit
                NEXT row
                Gosub gokey
    It just clears the stack. AND Maybe your pause 100 is faster than your key finger too
    france
    Default keypad
    Hi
    Yes, but the variable code0 has 1, 2 account code1, code2 account 3 code 3 has 4
    IF i = 0 THEN
    code0 = 1 >>>>> xkey
    IF i = 1 THEN
    code1 = xkey >>>>>> 2
    IF i = 2 THEN
    code2 = xkey
    IF i = 3 THEN
    Code3 = xkey >>>>>> 4
    PAUSE 50
    i = i + 1
    So it is, I think the problem comes from the relaxation of the?
  1. Matrix Keypad routine
    By mister_e in forum Code Examples
    Last Post: - 18th September 2022, 21:30
  2. 4x4 keypad Help
    By aaliyah1 in forum mel PIC BASIC Pro
    Last Post: - 5th October 2010, 17:34
  3. Keypad input test
    By Kalind in forum mel PIC BASIC Pro
    Last Post: - 8th October 2008, 05:00
  4. Need help in matrix keypad coding
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 24th May 2008, 14:16
  5. Keypad unlock (as in garage door possibly)
    By Fred in forum Code Examples
    Last Post: - 2nd April 2006, 05:26
