Shorting out a triac
Results 1 to 3 of 3
    Jun 2007
    Mansfield, UK
    Default Shorting out a triac
    Hi, I think i know the answer to this one but as im messing with 240V again i thought its best to ask here first.
    I want to have a triac and opto isolator that allows a PIC chip to control a bulb. I also want to be able to turn the bulb on using a normal switch. Can i just put the switch across the 2 high voltage pins on the triac? Would that cause a problem if i accidentally turned the switch on while the triac is controlling the bulb?
    I know i could have the switch short out the low voltage side but the switch is already connected and im just adding a triac to it but i can re-wire if shorting out the high voltage side would cause a problem.
    Can i just put the switch across the 2 high voltage pins on the triac? : Yes.
    Would that cause a problem if i accidentally turned the switch on while the triac is controlling the bulb? : No.
    Jun 2007
    Mansfield, UK
    Ok, Thats what i thought but thanks for confirming it
  1. Controlling a solenoid with a triac
    Last Post: - 26th October 2008, 01:38
  2. Possible triac problem
    Last Post: - 16th December 2007, 10:25
  3. need help in controlling Fan speed using TRIAC
    By vu2iia in forum Schematics
    Last Post: - 28th September 2007, 08:15
  4. Logic Level Triac
    By emavil in forum mel PIC BASIC Pro
    Last Post: - 29th November 2006, 19:18
  5. Decoding DMX with picbasic pro
    By fred.pacc in forum mel PIC BASIC Pro
    Last Post: - 11th September 2006, 15:34
