Shiftin pic18f452
Results 1 to 9 of 9
    Apr 2006
    Ok, I see. Thanks very much.
    Apr 2006
    It's been awhile since I worked with picbasic pro. I get an error with:
    Clock var PORTB.7
    Load var PORTB.6
    Data_1 var PORTB.5
    Don't know why.
    Thanks.
    Apr 2006
    Fixed, I think. I had some kind of conflict with the pin assignments. (I think).
    Thanks again.
    What is the error?
    is there more to your code? do you like guessing games?
    Yes, I am a smart _ _ _ ..
    EDIT>>>
    I need to see if a post was made while I am typing. Or type faster...
    Apr 2006
    Sorry. I have it all fixed now using your code above. I was pasting it into some old code and wasn't paying attention.
    I'll post my code when I get it finished.
    Thanks for your help, I appreciate it very much.
    Apr 2006
    I was wondering if anyone could check my code here and see if there are any boo-boo's.
    I am not getting the results I have expected. I am using a 4021 shift register sending serial data out to the pic18F452.
    I have buttons connected to the 4021 (parallel to serial chip) and send the bits out to the pic. I just wanted to test it by having the pic receive a byte (%00000001) and then light up an LED.
    It worked intermittently, but not really.
    'DEFINITIONS'
    DEFINE OSC 20
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 15
    'serial registers
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_BAUD 31250
    'PORT SETUP'
    TRISA = %11111111
    ADCON1 = %10000010
    'VARIABLES'
    keys        var byte
    A_Button    var byte
    B_Button    var byte
    Select_Button   var byte
    Start_Button    var byte
    Up_Button   var byte
    Down_Button var byte
    Left_Button var byte
    Right_Button var byte
    A_Button = %00000001
    B_Button = %00000010
    Select_Button = %00000100
    Start_Button = %00001000
    Up_Button = %00010000
    Down_Button = %00100000
    Left_Button = %01000000
    Right_Button = %10000000
    ''Pin Assignments''
    data_in var portb.7
    latch var portb.6
    clock var portb.5
    pulsout latch, 1    'toggle the latch pin
    shiftin data_in, clock, 0, [keys]
    if keys = A_Button then    'if A button pressed light LED on RB0
    high portb.0
    pause 1
    low portb.0
    The pause 1 seems to be to fast to see.
    Try having the LED come on for at least 100ms
  1. Shiftin question
    By ronjodu in forum mel PIC BASIC Pro
    Last Post: - 11th November 2007, 20:09
  2. communicating pic18f452 with pic16f877a
    By tamersoss in forum mel PIC BASIC Pro
    Last Post: - 13th July 2007, 20:54
  3. SHIFTIN problem
    By champion in forum mel PIC BASIC Pro
    Last Post: - 29th January 2007, 04:31
  4. Using SHIFTIN
    By TonyA in forum mel PIC BASIC Pro
    Last Post: - 31st May 2006, 16:38
  5. PIC18F458 Shiftin / Out
    By pberhin in forum mel PIC BASIC Pro
    Last Post: - 29th May 2006, 21:36
