Here is a snippet.
In this case the Load would be the same as your Latch.
Code:Clock var PORTB.7 Load var PORTB.6 Data_1 var PORTB.5 '########### pulsout Load,1 shiftin Data_1,Clock,MSBPre,[keys]
Here is a snippet.
It's been awhile since I worked with picbasic pro. I get an error with:
Clock var PORTB.7
Load var PORTB.6
Data_1 var PORTB.5
Don't know why.
Thanks.
Fixed, I think. I had some kind of conflict with the pin assignments. (I think).
Thanks again.
What is the error?
is there more to your code?do you like guessing games?
Yes, I am a smart _ _ _ ..
EDIT>>>
I need to see if a post was made while I am typing. Or type faster...
Sorry. I have it all fixed now using your code above. I was pasting it into some old code and wasn't paying attention.
I'll post my code when I get it finished.
Thanks for your help, I appreciate it very much.
I was wondering if anyone could check my code here and see if there are any boo-boo's.
I am not getting the results I have expected. I am using a 4021 shift register sending serial data out to the pic18F452.
I have buttons connected to the 4021 (parallel to serial chip) and send the bits out to the pic. I just wanted to test it by having the pic receive a byte (%00000001) and then light up an LED.
It worked intermittently, but not really.
Code:'DEFINITIONS' DEFINE OSC 20 DEFINE ADC_BITS 10 DEFINE ADC_CLOCK 3 DEFINE ADC_SAMPLEUS 15 'serial registers DEFINE HSER_RCSTA 90h DEFINE HSER_TXSTA 20h DEFINE HSER_BAUD 31250 'PORT SETUP' TRISA = %11111111 ADCON1 = %10000010 'VARIABLES' keys var byte A_Button var byte B_Button var byte Select_Button var byte Start_Button var byte Up_Button var byte Down_Button var byte Left_Button var byte Right_Button var byte A_Button = %00000001 B_Button = %00000010 Select_Button = %00000100 Start_Button = %00001000 Up_Button = %00010000 Down_Button = %00100000 Left_Button = %01000000 Right_Button = %10000000 ''Pin Assignments'' data_in var portb.7 latch var portb.6 clock var portb.5 main: pulsout latch, 1 'toggle the latch pin shiftin data_in, clock, 0, [keys] if keys = A_Button then 'if A button pressed light LED on RB0 high portb.0 pause 1 low portb.0 endif goto main
The pause 1 seems to be to fast to see.
Try having the LED come on for at least 100ms
