Yes, I guess so too, no need for changing the version of the includes if nothing in them have been changed.
and I comented out everything in the correct include, now it looks like:
..And the actual code look like:Code:;**************************************************************** ;* 18F2520.INC * ;* * ;* By : Leonard Zerman, Jeff Schmoyer * ;* Notice : Copyright (c) 2006 microEngineering Labs, Inc. * ;* All Rights Reserved * ;* Date : 06/05/06 * ;* Version : 2.47 * ;* Notes : * ;**************************************************************** NOLIST ifdef PM_USED LIST "Error: PM does not support this device. Use MPASM." NOLIST else LIST LIST p = 18F2520, r = dec, w = -311, w = -230, f = inhx32 INCLUDE "P18F2520.INC" ; MPASM Header ; __CONFIG _CONFIG1H, _OSC_INTIO7_1H ; __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H ; __CONFIG _CONFIG3H, _PBADEN_OFF_3H ; __CONFIG _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L NOLIST endif LIST EEPROM_START EQU 0F00000h BLOCK_SIZE EQU 64
..And it compiled with no errors.Code:asm __CONFIG _CONFIG1H, _OSC_INTIO67_1H & _FCMEN_OFF_1H & _IESO_OFF_1H __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H __CONFIG _CONFIG3H, _CCP2MX_PORTC_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_OFF_3H __CONFIG _CONFIG4L, _STVREN_OFF_4L & _LVP_OFF_4L & _XINST_OFF_4L endasm DEFINE OSC 32 ' internal 8MHz x 4 with PLL enabled blueled var LATB.4 ' prevents read-modify-write redled var LATB.5 ' problems OSCTUNE = %0100000 ' turn on PLL for 4 x 8MHz OSCCON = %01110000 ' set 8MHz internal osc ADCON1 = %00001111 ' disable all A/D main: low redled low blueled pause 500 high redled pause 500 high blueled pause 500 goto main END
The setup is just a PIC18F2520 with pin20 connected to +5V, 8/19 to gnd,
a 10k resistor from pin1 (MCLR) to +5V, and two LED's connected via resistors
from pin 26 (RB5) and 25 (RB4) I also added two cap's between Vcc and gnd,
one 1uF and one 100nF.
I also have a pickit2 connector wired up to usual pins.
..And now I'm going to the bed![]()
