Trying to migrate to 18F..
Results 1 to 30 of 30
    Quote Originally Posted by Glenn View Post
    Just an example of working configbits for internal oscillator that works on 20MHz would be great, then I could try things after that, but now I cant even get the damned thing to run..
    Section 2.6 datasheet.
    section 2.64 " "
    32 mhz is your speed limit using PLL and internal osc.
    Set it up in OSCCON register
    Sep 2008
    Stockholm
    section 2.64 " "
    Well, at maximum I presume ? actually I don't really understand what they mean exactly in that part of the datasheet, I would belive that I set one speed on the oscillator, and then the PLL multiplies it ? then 8x4 would give 32Mhz ? ..Ofcourse that would give me troubles to get excactly 20Mhz then, but still, it would work I think ? (but for exampe, "pause 1000" would not be one second)
    Anyway, I could use another clock frequency too, the main reason to use 20Mhz is that I tried the same program on a 16f PIC with no internal oscillator, and then I used a 20Mhz xtal.
    Did you write it @ __CONFIG _CONFIG1H, _OSC_INTIO67_1H & _FCMEN_OFF_1H & _IESO_OFF_1H ; enable int osc, disable failsafe osc enable, disable internal external switchover ?
    As for ' , is a PBP compiler directive, whereas ; directs both compiler and assembler
    with no comment at all..
    I don't have an 18F2520 to test this on, but give this a try;
    asm
      __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
      __CONFIG _CONFIG3H, _CCP2MX_PORTC_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_OFF_3H
      __CONFIG _CONFIG4L, _STVREN_OFF_4L & _LVP_OFF_4L & _XINST_OFF_4L
    endasm
    DEFINE OSC 32     ' internal 8MHz x 4 with PLL enabled
    blueled var LATB.4 ' prevents read-modify-write
    redled  var LATB.5 ' problems
    OSCTUNE = %0100000 ' turn on PLL for 4 x 8MHz
    OSCCON = %01110000 ' set 8MHz internal osc
    ADCON1 = %00001111 ' disable all A/D
      low redled
      low blueled
      high redled
      high blueled
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sep 2008
    Stockholm
    bruce:
    I get this..
    Warning[230] C:\PBP\LTIMERT3.ASM 64 : __CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
    Error[113] C:\PBP\LTIMERT3.ASM 64 : Symbol not previously defined (_OSC_INTIO67_1H)
    Warning[230] C:\PBP\LTIMERT3.ASM 65 : __CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
    Warning[230] C:\PBP\LTIMERT3.ASM 66 : __CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
    Error[113] C:\PBP\LTIMERT3.ASM 66 : Symbol not previously defined (_CCP2MX_PORTC_3H)
    Warning[230] C:\PBP\LTIMERT3.ASM 67 : __CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
    Hi Glenn,
    Newer versions of PBP include w = -230 in the .INC file that gets rid of the deprecated
    warning.
    I.E. a new version .INC file looks something like this if you have the default config settings
    commented out.
       NOLIST
        ifdef PM_USED
            LIST
            "Error: PM does not support this device.  Use MPASM."
            NOLIST
            LIST
            LIST p = 18F2520, r = dec, w = -311, w = -230, f = inhx32
            INCLUDE "P18F2520.INC"   ; MPASM  Header
           ; __CONFIG _CONFIG1H, _OSC_INTIO67_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
           ; __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
           ; __CONFIG _CONFIG3H, _CCP2MX_PORTC_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
           ; __CONFIG _CONFIG4L, _STVREN_OFF_4L & _LVP_OFF_4L & _XINST_OFF_4L
            NOLIST
            LIST
    EEPROM_START	EQU	0F00000h
    BLOCK_SIZE	EQU	64
    These are all you have commented out right? What version of PBP are you using?
    -Bruce
    tech at rentron.com
    Sep 2008
    Stockholm
    I'm using 2.50b, and my include looks like:
    ;*  18F2550.INC                                                 *
    ;*  By        : Leonard Zerman, Jeff Schmoyer                   *
    ;*  Notice    : Copyright (c) 2004 microEngineering Labs, Inc.  *
    ;*              All Rights Reserved                             *
    ;*  Date      : 12/31/04                                        *
    ;*  Version   : 2.46                                            *
    ;*  Notes     :                                                 *
            NOLIST
        ifdef PM_USED
            LIST
            NOLIST
            LIST
            LIST p = 18F2550, r = dec, w = -311, f = inhx32
            INCLUDE "P18F2550.INC"	; MPASM  Header
            ;__CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
            ;__CONFIG    _CONFIG1H, _FOSC_HS_1H
            ;__CONFIG    _CONFIG2H, _WDT_ON_2H & _WDTPS_128_2H
            ;__CONFIG    _CONFIG3H, _PBADEN_OFF_3H
            ;__CONFIG    _CONFIG4L, _LVP_OFF_4L & _ICPRT_OFF_4L & _XINST_OFF_4L
            NOLIST
            LIST
    BLOCK_SIZE	EQU	32
    However, its not the warings that I have problems with, its the errors
    Sep 2008
    Stockholm
    Hmm, strange. I thought the "version 2.46" was a bit suspect, so I looked one time more, and found a "18f2520.inc.org", which probably is the correct file, and the other is something I cut'n'pasted in from someone else ?
    That one looks like:
    ;*  18F2520.INC                                                 *
    ;*  Notice    : Copyright (c) 2006 microEngineering Labs, Inc.  *
    ;*  Date      : 06/05/06                                        *
    ;*  Version   : 2.47                                            *
    ;*  Notes     :                                                 *
            NOLIST
        ifdef PM_USED
            LIST
            NOLIST
            LIST
            __CONFIG    _CONFIG1H, _OSC_XT_1H
            __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
            NOLIST
            LIST
    BLOCK_SIZE	EQU	64
    Still bot 2.50b, but 2.47, but maybe the includes only get updated when needed. (sounds logical)
    Also I didnt do a clean install, I upgraded from an old version.
  1. 16F to 18F transition pains
    By lurker in forum mel PIC BASIC Pro
    Last Post: - 5th December 2008, 01:35
  2. 18F Config fuses
    By Angus Anderson in forum mel PIC BASIC Pro
    Last Post: - 18th December 2007, 15:59
  3. Super easy 18F print strings to UART
    Last Post: - 26th August 2007, 23:19
  4. Upgrading 16F to 18F
    By Ron Marcus in forum General
    Last Post: - 29th March 2006, 09:44
  5. Newby- PBP wont compile for 18F (MPLAB)
