I have the MicroCode Studio Plus installed and am having trouble getting it to connect.
I am using the 18F1320
Here is a portion of my code:
 include "BS2DEFS.BAS"
     'OSCCON =$ff 'clock speed
     OSCCON = $62
     ADCON0 = 0   'diable A/D
     ADCON1= 127  'all digital out
     define OSC 4
     ' Set Debug pin port
	DEFINE DEBUG_REG	PORTB
	define DEBUGIN_REG PORTB
	' Set Debug pin bit
	DEFINE DEBUG_BIT	4
    DEFINE DEBUGIN_BIT  2
    define DEBUG_PACING 2000
	' Set Debug baud rate
	DEFINE DEBUG_BAUD	2400
	' Set Debug mode: 0 = true, 1 = inverted
	DEFINE DEBUG_MODE	1
	define DEBUGIN_MODE 1
           'TRISA = 0
     led1 var PORTA.0
     led2 var PORTA.1
     led3 var porta.2
     led4 var porta.3
     led5 var porta.4
     x var byte
     loop:
         debug "hello world",cr ,10
       for x = 255 to 1 step-5
       pwm   led1,x,10
       if x < 60 then high led2
       'if x < 25 then high led3
       next x
When I compile amd program with ICD then click the play button it cannot connect
I can read the "hello world" on the Hyper Terminal
Any Ideas as to what is wrong?
Mike2545
