Zero-crossing detector?
Results 1 to 14 of 14
    Thats a good circuit Don, but i'd also use a 47E resistor in series with the 0.1 uf cap.
    Anand
    Omaha, Nebraska USA
    I guess I wasn't very clear . . .
    I don't need a transformerless power supply for the PIC circuit and associated glue; I was looking just for a transformerless zero-crossing detector.
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Feb 2005
    Kolkata-India
    Default Simple but works
    You can also use a NPN inverter from the rectified DC for sharper (inverted zero cross).
    Last edited by sougata; - 11th August 2009 at 09:39. Reason: If you use a transformer this could be handy
    Sougata
    Jun 2007
    Mansfield, UK
    Recently ive been using this idea. That page describes how to run an LED from the mains but with just the capacitor and resistor you can run an AC input darlington opto. Ive been using this method for detecting the presence of AC but it should work fine to detecting a zero crossing too.
    I always use an opto for safety. I did try a huge resistor feeding directly into the PIC which seemed to work fine till i connected the PIC to my laptop through serial and the laptop turned itself off.
    My prefered method is to use the 12V coming from the supply transformer. If you can use a transformer for the supply then you only need 2 extra diodes and a resistor to feed into the PIC.
    As for the code, i dont like using oninterrupt but i do use the interrupt flags. The program doesnt have to check the interrupt after each command that way. It checks it when you want.
    Feb 2005
    Kolkata-India
    Default Phase shifts the zero cross
    The zero-cross sensing is mostly used for phase angle control. The Master The circuit you mentioned would essentially phase shift the zero cross signal.
    BTW if you replace this idea with this idea then you get more ideas. Like this idea
    Thanks to the author of the site and The Master
    Sougata
    Dec 2005
    Quote Originally Posted by The Master View Post
    For ZC, the resistor is adequate given the PIC has clamp diodes on the inputs. If you need mains isolation for RS232, use optos in the RS232 lines.
  1. Replies: 6
    Last Post: - 10th September 2008, 11:04
  2. Crossing Page Boundary - Solution
    By Darrel Taylor in forum FAQ - Frequently Asked Questions
    Last Post: - 24th November 2007, 03:52
  3. IR detector
    By geckogrotto in forum mel PIC BASIC Pro
    Last Post: - 30th August 2006, 04:16
  4. Crossing Page Boundary .....
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 20th March 2006, 08:57
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
