74HC/HCT166 shift register datasheet, error...?
Results 1 to 16 of 16
Threaded View
  1. #4
    Bonjour Steve!
    Yup, I thought of that, same with PAUSEUS. I also use a button to shift in new data after I've sent +5V DC to one of the input pins on the 74HC166. Here's all my code, I even left in the indicator LEDs I've been using to display results:
    INCLUDE "MODEDEFS.BAS" ' Serial I/O modes
    LIST
    INCLUDE 'M16F62X.INC' ; PM header
    DEVICE PIC16F628, HS_OSC, WDT_OFF, PWRT_ON, MCLR_OFF, LVP_OFF, PROTECT_OFF
    XALL
    NOLIST
    DEFINE OSC 20 ' Set oscillator speed
    DEFINE SHIFT_PAUSEUS 3 ' Slow down SHIFT in/out commands by 3uSECS
    CMCON = 7 ' Set PORT A pins to digital
    SHFTIQ7 VAR PORTB.0 ' Input data
    SHFTICP VAR PORTB.1 ' Input clock pulse
    SHFTICE VAR PORTB.2 ' Input clock enable
    SHFTIPE VAR PORTB.3 ' Input parallel enable
    BUTTONI VAR PORTA.4 ' Input user entry
    LED1 VAR PORTA.2 ' Bit active indicator
    LED2 VAR PORTA.3 ' Loop indicator
    LOOP VAR BYTE
    DATAI VAR BIT[16]
    HIBIT CON %1
    HIBYTE CON 1
    START: DATAI = 0 ' Initialize variables
    LOOP = 0
    GOSUB REQBUT ' Wait for user input
    LOW SHFTIPE ' Initiate parallel load of bits
    LOW SHFTICE
    GOSUB CYCCLK
    HIGH SHFTIPE ' Initiate serial shift of bits
    LOW SHFTICE
    GOSUB CYCCLK
    HIGH SHFTICE ' Initiate hold of shift registers
    SHIFTIN SHFTIQ7,_ ' Shift in bits from registers
    SHFTICP,_
    LSBPRE,_
    [DATAI\16]
    FOR LOOP = 0 TO 15 ' Check bits for a high bit
    GOSUB BITNUM
    IF DATAI = HIBIT THEN
    GOSUB HIFND
    NEXT LOOP
    GOTO START ' Restart processing
    FINISH: END ' Terminate processing
    ' SUB-ROUTINES
    REQBUT: GOSUB FLASH ' Process user input
    IF BUTTONI <> HIBYTE THEN GOTO REQBUT
    RESUME
    FLASH: HIGH LED1 ' Indicate waiting for user input
    HIGH LED2
    PAUSE 250
    LOW LED1
    LOW LED2
    PAUSE 250
    CYCCLK: LOW SHFTICP ' Cycle clock pulse
    HIGH SHFTICP
    RESUME
    BITNUM: HIGH LED2 ' Indicate bit number within string
    PAUSE 250
    LOW LED2
    PAUSE 250
    HIFND: HIGH LED1 ' Indicate bit is high
    PAUSE 250
    LOW LED1
    PAUSE 250
    If I jst connect the input pins to the PIC to GND, all the bits are 0, if I connect to +5V DC, all the bits are 1, which is what I expect. I'm stumped.
  1. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 21:31
  2. PIC16F877A pwm use for IR transmission
    By mcbeasleyjr in forum General
    Last Post: - 11th July 2009, 19:51
  4. Optimizing DIV
    Last Post: - 22nd September 2008, 05:58
  5. Replacing shift register with PIC
    By TonyA in forum mel PIC BASIC Pro
    Last Post: - 7th April 2008, 19:31
