ADC121C021 I2C problems
Results 1 to 5 of 5
    I didn't notice the attachment at first, and searched online for the datasheet.
    Your's was from 2008, and I found this one at National from April, 2009.
    There are considerable differences in the addressing scheme between the two.
    And the big question is ... are you using the MSOP-8 package?
    See section 1.7.4 I2C Slave (Hardware) Address
    http://www.national.com/ds/DC/ADC121C021.pdf
    It shows that the addresses should be between A0 and A6, depending on PIN configurations.
    Jun 2009
    Cambridge, England
    I'm using the TSOT package which has a fixed slave address. The ADDR pin is used as an alert on this one.
    I think using an address of A3 should work on my device but it doesn't. I get a response from the device with addresses of A8 and A9. These appear to return the lowest and highest conversion values.
    I haven't messed around with the result register pointer as I think it should be at 0h.
    Ok, I see what happened ...
    The address listed in the datasheet is only 7-bits 1010100.
    When you add the read/write bit it becomes $A8, 1010:1000
    And I think the pointer address should be sent with I2CWRITE before an I2CREAD, instead of in the I2CREAD.
    Yes it's default to 0, but this should work for all registers ...
    slave_address=$A8
    adc_register=0
    I2CWRITE i2cdata,i2cclock,slave_address,[adc_register]
    I2Cread i2cdata,i2cclock,slave_address,[data_read.Byte0, data_read.Byte1],error
    hth,
    Jun 2009
    Cambridge, England
    Thanks for that Darrel
    Unfortunately this gives me the same result as previous. This works ok but it is only in steps of 8. Typical values from the adc are 288,280,272 etc. This means my actual resolution is only 10 bits, not 12.
    The overall output is correct, with zero input I get about zero output from the adc, and for 5 volts input I get about 4000 out.
    I'll have another look at the data sheet. I don't think this is a PBP problem but I would welcome any suggestions.
    RS
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. I2C Read/Write problems
    By Dispersion123 in forum mel PIC BASIC Pro
    Last Post: - 5th April 2008, 16:11
  4. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  5. Please help with i2cslave i2c slave
    By cycle_girl in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 14:55
