Like Tim asked, can you see anything on the display? You may want to look at the PBP manual to see how to use a pot with the contrast pin.
And I will ask. Can you make an LED blink at the correct rate? Maybe the PIC is not even running?
If the PIC is running at the correct speed and you can change the contrast it could be in the commandus or dataus settings.
