MCP23016 Question
Results 1 to 2 of 2
    Jun 2006
    Default MCP23016 Question
    After using MCP23016 for quite sometime, at last i discovered something unusual.
    I have been using 2 MCP23016 differentiate by the address to 1 PIC. The task is very easy, read from 1 unit and display to another unit. The code works fine. The circuit works fantastic.
    Until one day i accidentally break the SDA line ( point A in the schematic ). All LED at the display unit all goes OFF except LEDs connected to GP0.1 and GP1.1. The same scenario happen if the point B is break. I tried different approach in programming and wiring but the results is similar. S0me how GP0.1 and GP1.1 activated.
    Can anyone explain.
    Thank you..
    Cheers,
    mychangl
    "The Dream Is Everything"
    Jun 2009
    Cambridge, England
    I don't know much about this device but if you disconnect the i2c data or clock connections, the output latches will contain the values from where the communication stops. Without seeing the program I'm not sure why it always stop with the GP0.1 and GP1.1 latched.
    RS
  1. Crystals & Caps - Super noob question??
    By kevj in forum General
    Last Post: - 24th September 2007, 18:11
  2. FREQOUT - PWM question
    By Etcho in forum mel PIC BASIC Pro
    Last Post: - 26th February 2007, 00:51
  3. Question for a math guru
    Last Post: - 22nd November 2006, 10:45
  4. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 07:49
  5. MCP23016 I/O expander with PBP?
    By Jon Chandler in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2005, 10:32
