LCD Memory Writing
Results 1 to 11 of 11
    May 2007
    Too bad. I had high hopes for this.
    From Micros web site
    Static RAM or SRAM
    Static Random Access Memory. Program memory you can Read/Write on the target board that does not need refreshing frequently.
    Look to you data sheets. Many have SRAM.
    May 2007
    Does the static ram retain its contents when you power off?
    May 2007
    Anything?
    Not on a PIC.
    Sorry, I haven't been paying attention to this thread... I implied (perhaps erroneously) that all Static RAM is non-voltatile (trouble when reading too many different manufacturers product Datasheets). Only some types are. I haven't gone through all of Microchips offerings so I can't answer if there is non-volatile RAM amongst their product range - a question that could be posed to their technical enquiry line.
    May 2007
    There are no Microchip (or Atmel, Freescale, Infineon, Renesas, ST, TI, etc.) offerings that have non-volatile Static RAM. The only MCU's with non-volatile RAM are a few from Fujitsu and Ramtron - however, their RAM is implemented as FRAM (ferro-magnetic RAM) which is quite a different technology altogether.
    There are also external RAM devices based on the above mentioned FRAM and BBSRAM (battery backed Static RAM) from several sources.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  5. LCD will not start
