can i slowdown owin and owout
Results 1 to 6 of 6
    Eugen's Avatar
    Eugen Guest
    Default can i slowdown owin and owout
    i have a problem i am using 3 ds18b20 and if i use a 8mhz crystal and use DEFINE OSC 8 it dosent work but if i change DEFINE OSC 8 to DEFINE OSC 16 then it works. can i slow down the owin and owout? i am using 3*15 meter cat5 cabel this is the program or what sould i do?
    DEFINE OSC 8
    ADCON1 = 7
    DEFINE LCD_EREG PORTA
    DEFINE LCD_EBIT 5
    TRISB = %11111111
    TRISC = %11111111
    DQ VAR PortC.0
    Stat VAR BIT
    S1 Var byte
    S2 Var byte
    S3 Var byte
    A VAR WORD
    B VAR WORD
    start:
    S1 = $E5
    S2 = $93
    S3 = $1E
    gosub Temp
    A=B
    S1 = $86
    S2 = $81
    S3 = $7B
    gosub Temp
    A=A >> 3
    B=B >> 3
    Lcdout $fe, 1
    Lcdout dec (A >> 1),".",dec(A.0 * 5)
    Lcdout $fe, $C0
    Lcdout dec (B >> 1),".",dec(B.0 * 5)
    pause 2000
    goto start
    Temp:
    OWOUT DQ, 1, [$55,$28,S1,S2,$79,$00,$00,$00,S3,$44]
    Pause 1000
    OWOUT DQ, 1,[$55,$28,S1,S2,$79,$00,$00,$00,S3,$BE]
    OWIN DQ, 2, [B.LOWBYTE,B.HIGHBYTE]' Read two bytes, then end communications
    Dec 2003
    Wichita KS
    Hello Eugen,
    E>>i have a problem i am using 3 ds18b20 and if i use a 8mhz crystal and use DEFINE OSC 8 it dosent work but if i change DEFINE OSC 8 to DEFINE OSC 16 then it works. can i slow down the owin and owout? i am using 3*15 meter cat5 cabel this is the program or what sould i do?<<
    My knowledge has not been in this area, but one BIG question would rise in my head...
    Baudrate... is the Baudrate accurate and stable at OSC 8 at the speed you are going? OSC 8 may be too slow to use a baud that will produce a guaranteed stable communication. Its like attempting to use 9600 baude with a 4mhz Crystal...Flakey, if not worthless.
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    Feb 2004
    Germany
    Dwayne
    good to see you back on the forum !
    OWIN and OWOUT has nothing to do with Baudrate.
    Eugen
    I think there is only one way to control 1wire comms speed:
    Write your own 1wire routines and don't use OWIN and OWOUT.
    (I had to do this with I2C on one of my projects, but I haven't tried it with 1wire yet)
    regards
    Ralph
    Eugen's Avatar
    Eugen Guest
    I change the pull-up to a smaller then its works
    Feb 2004
    Germany
    Eugen,
    what value were you using initially for the pullup and what value are you using now ?
    regards
    Ralph
    Eugen's Avatar
    Eugen Guest
    i was using 4.7k and now i use 4.7 and a 10k pot so i dont know what i have now
  1. Please help with code for DS18B20
    Last Post: - 28th April 2013, 21:12
  2. Ds18b20 + 16f628a
    By Max Power in forum mel PIC BASIC Pro
    Last Post: - 16th July 2009, 11:29
  3. DS2438 onewire code sample
    By Captain Stern in forum mel PIC BASIC Pro
    Last Post: - 21st January 2007, 02:47
  4. Help with DS2436 Voltage monitor
    By vladimir059@hot in forum mel PIC BASIC Pro
    Last Post: - 30th October 2006, 16:39
  5. Can anyone help at getting OWIn & OWOut to work @ 16MHz?
    Last Post: - 24th January 2006, 11:08
