Hello All,
I looked through the archive and did not find a working solution to my problem. I am using a USB MELABS in-circuit programmer which works on just about everything I have used, except the 12F series. I am about to set a new punt record with my programmer! gggrrrr
I tested two setups....
1). external power 5vdc on the chip and isolated MCLR pullup....which works fantastically well for the 16F series. This method did not work for the 12F
2). I used a voltage regulator on the VPP line to power the MCU, a recommendation from an archive post. That VPP needs to come up before power up or vise versa. This did not work either.
The error is the same regardless of the method. It initiates erase upon programming, then programs and when it verifies it sees a memory content error 000 or something to that effect.
No, I don't have an adapter to program the IC outside of the circuit, that was the whole reason I chose ICSP.
HELP!!!!!
Nick
