PIC 16f877 A/D conversion Allegro ACS712
Results 1 to 33 of 33
    Nope, can't go that route.
    You ARE measuring currents from inductive loads (submersible pumps).
    So you have to get an RMS reading.
    You would be surprised just how far off the numbers will be. >100%
    I know this too well, because I went down that same road my first time too.
    It was horrible.
    Down right embarrassing actually, since the customer saw it too.
    Jan 2008
    Pennsylvania
    Default I trust your experience.
    It was horrible.
    I trust you.
    I just wanted to double check myself. I am just playing around now with the min/max on an 85w bulb and just this 85w bulb gives me a bad reading. I get for MAX 132 and MIN is 124 so it's a little off if I run this through the calculation you provided me I get
    (132 - 127 ) * 196 / 66 = 1.48
    (127 - 124 ) * 196 / 66 = .89
    Even avergaing these 2 I come up with 1.18 that is that is double what the clamp meter is telling me is .66 which I tend to believe now because since it truly should be .7 the fact the clamp is telling me .66 and how can I really tell if this bulb is putting off truly 85w.
    Here is something I am seeing that is strange. If I plug the 1600w hairdryer that has 2 settings I get 2 readings as you would expect on low I get 152 MAX and 103 MIN then for the high setting I get 179 MAX and 76 MIN but when I plug in the 10 amp hot air gun which also has 2 settings when I set it on low I get 172 MAX and 127 MIN with the reading I get from the hair dryer I would have expected the min reading on the hot air gun to go to 82 that is goofy why would the hot air gun get such a different result then the hair dryer?
    The LTC is on it's way I found those at digikey looking for the little board for it now. Also getting the TLV324 would it be to much trouble to get a look at how you wired that up with both components to the pic?
    David
    OUCH!
    You should have searched for 33108 at digikey before ordering.
    http://search.digikey.com/scripts/Dk...keywords=33108
    I'm betting UPS does well this quarter.
    And no, I can't really show the schematics or anything, but It's no big secret ...
    If you were to trace out the components in the picture I showed above ...
    You would find the EXACT schematic shown in the datasheet under the heading "Single Supply RMS Current Measurement". The only difference is that I used a different current transformer, and changed the "burden" resistor to 51 ohms. Otherwise, identical.
    Add a little gain for the PIC's A/D and you're good to go.
    hth,
    Jan 2008
    Pennsylvania
    Default Did I miss something?
    hth,
    Did I miss something or are you using the ACS712 in this circuit or not at all? It sounded like you were running this 712 into this but reviewing this schematic I don't think you are even using the 712 now.
    David
    It does not use an ACS712 in that circuit.
    I'm showing the LTC1966 RMS convertor, which is needed whether the signal comes from a current transformer, a hall-effect sensor, or just a BIG honken shunt resistor that would heat your toaster oven.
    It's the RMS conversion that matters.
    Jan 2008
    Pennsylvania
    Default understood.
    I'm showing the LTC1966 RMS convertor, which is needed whether the signal comes from a current transformer, a hall-effect sensor, or just a BIG honken resistor that would heat your toaster oven.
    I am sorry I am not trying to tick you off or anything but I have to question this one last time. What is pumping the same signal through the LTC1966 going to give me that I can't figure out myself? I guess that is the part I am having trouble comprehending. The ACS712 data sheet says it's good for sensing current for motor control, load detection, etc... No matter what the ACS712 is going to output a voltage that is in direct proportion to the current it senses. Granted it's going to follow the wave form of the AC current it's still going to be proportinate to the peak current arghhhhh I need to go do something else for a while and stop thinking about this.
    I'm not giving up on this I know I will get it.
    Jan 2008
    Pennsylvania
    Default got it!
    OUCH!
    I got the little boards from there as well. I meant on it's way meaning it was in my cart. I know better to wait until the end of the day to place my order and commit
    I'm having trouble locating that op amp though...
  1. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 02:48
  2. A/D conversion problem in 18F2520, 2523, 2550 etc.
    By selimkara in forum mel PIC BASIC Pro
    Last Post: - 10th March 2008, 17:26
  3. 16f877 A/D help
    By 3adam in forum mel PIC BASIC Pro
    Last Post: - 25th January 2008, 05:06
  4. A/D converter fails?
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 13th February 2006, 19:57
  5. Strange A/D conversion...
    By Christos_K in forum mel PIC BASIC Pro
    Last Post: - 5th June 2005, 02:35
