PIC 16f877 A/D conversion Allegro ACS712
Results 1 to 33 of 33
    Jan 2008
    Pennsylvania
    Default I get it but must be doing something wrong.
    Darry and Mack thanks very much for your response. I undersatand the 2 different ways you came to your solution. Either my ACS712 is fried or I am doing something wrong. I am passing AC through the 712. No matter which math I use the current reading seems to high but 2 to 3 amps. That is according to my clamp meter I am using taking a reading at the same time and the device I am using to test this. I am running a heat gun which states on the side it's 1200 watt 10amp heat gun.
    Any suggestions? I can post my code it's a very simple program.
    I appreciate the help, I've got to sweep up this big pile of hair I just yanked from my head
    David
    Apr 2009
    Pittsburgh, PA
    Default Diagram we use
    I drew this diagram to illustrate the different units involved.
    For a numeric value of 166 read from the analog-to-digital converter, Darrin's equation brings back 11.58 and Mackrackit's brings back 11.47.
    They are close enough given the low resolution arithmetic taking place especially if you just round up to no decimal places.
    I can attest to the annoyance of one meter showing 9 Amps when the equations bring back the numbers above.
    http://www.picbasic.co.uk/forum/albu...0&pictureid=25
    Last edited by ukemigrant; - 3rd August 2009 at 01:06. Reason: Stupid image did not show up
    Quote Originally Posted by DavyJones
    What Dave and I both "assumed" was that you were measuring DC currents.
    The part about an A/C signal would have helped in the beginning.
    Being that the heat gun is mainly a resistive load, you could get a much closer reading by finding the highest (peak) voltage and multiply by 0.707, which gives the R-M-S value of a perfect sine wave. Then convert to current.
    The heat gun also has a fan, which is an inductive load, so you'll never get a perfectly "accurate" reading with the 0.707 multiplier. But since the fan is only a small portion of the load it would be closer.
    But I doubt the eventual use of your project will be measuring the current from heat guns. And the type of load makes a HUGE difference.
    If you'll be primarily measuring motor currents, the wave forms will NOT be sine, and .707 will not even come close. In that case, there is only one way to go.
    Run the signal from the current sensor into an R-M-S converter. Don't bother trying to do it in software. I like the LTC1966, but it's a really tiny chip and isn't great for hobby use cause they're too hard to solder.
    There are several other chips available that do the same thing. But for sure you will need an R-M-S (Root Mean Square) reading for any inductive loads.
    Dec 2005
    You can also take many readings (~100 x the frequency or 6000Hz) and average them but I don't think a PIC can do this fast enough for accuracy. This is how digital wattmeters work.
    If an oscilloscope is not available, it might be possible to get an idea of the waveform using a PC or laptop with a LineIn port for the soundcard. The sampling rate should be adequate unless there are sharp spikes. Since the Allegro output is 0-5V, you can use the same technique I use for IR & RF. See...
    Not knowing more about the project a simple current transformer might be good enough. You would still need to calibrate it though.
    There are pros and cons to every option, but CTs are good enough for power companies to sell with...
    Let us know which way you want to go.
    Jan 2008
    Pennsylvania
    Default Good notes and advice as usual.
    Darryl, Your right I should have mentioned that I was trying to measure an AC current right off the bat my mistake.
    So I've got a couple differnt methods and since I want to learn I'm looking at both of these and am leaning more towards the LTC1966.
    Dave no I did not forget you and I have been taking many samples in my code but that does not seem to be working well for me but I do like your example of how to read this with the line in on the sound card and kind of simulate having an oscilliscope that is pretty cool and I am going to be doing that this evening.
    So to the RMS to DC converter. I'm reading the datasheet for the LTC1966 on it's functionality it sounds like as you said run the output of the 712 through and it is going to give me the DC voltage proportionate to the amps that I am trying to read on the pic correct? I'm going to get one and try it out so I can see this for myself.
    David
    Quote Originally Posted by DavyJones View Post
    Then get yourself some of the adapters shown below.
    The other picture is a 3-phase current sense board a did for a customer. You can see how small they are. They don't come in any larger packages.
    I was using current transformers instead of hall-effect sensors, but the idea (and RMS requirement) are the same for either type.
    I also had to use a TLV324 op-amp (not shown) to bring it up to levels the PIC could read accurately.
  1. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 01:48
  2. A/D conversion problem in 18F2520, 2523, 2550 etc.
    By selimkara in forum mel PIC BASIC Pro
    Last Post: - 10th March 2008, 16:26
  3. 16f877 A/D help
    By 3adam in forum mel PIC BASIC Pro
    Last Post: - 25th January 2008, 04:06
  4. A/D converter fails?
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 13th February 2006, 18:57
  5. Strange A/D conversion...
    By Christos_K in forum mel PIC BASIC Pro
    Last Post: - 5th June 2005, 01:35
