Still 12F675 question
Results 1 to 8 of 8
    France
    Default Still 12F675 question
    Hello
    I am still "playing" with a 12F675
    this is quite new for me
    I use
    ansel = 0 ' all digital
    cmcon = 7 ' comparator OFF
    TRISIO = %001001 ' GP0 et GP3 en INPUT
    OPTION_REG.7 = %110110 'pull up actifs
    My problem is : I have no signal on output port !
    question : may I have to use pull up resistors on output port
    or this option_reg.7 will switch internally thoses pull up ?
    (weak pull up story) on page 21 of the datasheet
    thanks in advance
    francois
    I would not mess with the weak pullups , just pretend they are not there for now.
    Can you post all of your code and configs? Makes it a bit easier to see what you have.
    France
    Default still 12F675 question
    Sorry for the delay, I was in vacation
    to be clear, I do not understand your answer , I'm french , so, english expressions
    are not so easy to understand ..
    I must work on my application and come back with more details
    to see if I need to connect pull up resistors (as in the past)
    or to "play" with option reg command !
    I will come back soon
    Francois
    Hello Francois,
    To have "all digital" you have the ADCON0 register to deal with, specifically the ADON bit which is ADCON0.0 which must be cleared either by ADCON0 = 0 or ADCON0.0 = 0
    Jul 2008
    TURKIYE-KONYA
    Default Option_reg.7
    option_reg.7 is just a bit.
    you should do this to activate pull-ups.
    OPTION_REG.7 = 0 ; activate pull-ups
    and you dont need to use pull-ups for output.
    France
    Hello
    I was STUPID with my option-reg.7 bit !
    May be I was swimming in all those bits in all those registers !
    I have made some changes, BUT the DUCK is still alive
    I have NO signal (digital) on ENAB, DTA and Clk
    LED is flashing (at least !)
    any ideas ?
    thanks
    hardware in PDF
    CODE in txt
  1. Extreme Noobie question 12F675
    By Jeff in forum mel PIC BASIC
    Last Post: - 22nd September 2009, 02:13
  2. 12f675 probably a silly question
    By Meriachee in forum mel PIC BASIC Pro
    Last Post: - 21st November 2006, 15:22
  3. 12F675, MPLAB programming question
    By EASY in forum General
    Last Post: - 2nd April 2006, 20:28
  4. 12f675 programming question
    By puggy in forum General
    Last Post: - 1st December 2004, 00:34
  5. 12f675 internal osc question.....
    By Gabe@SPdFtsh in forum mel PIC BASIC Pro
    Last Post: - 6th January 2004, 07:33
