Generating 5v from 4 batteries
Results 1 to 11 of 11
    One rubbish Silicon Diode in the Supply line will do the job... 0.6-0.7v drop and you're in business. OK, OK I know, don't lecture me, but I dare you to find a cheaper solution than about 0.5 of a cent!
    So you want to be pedantic and lose a whole volt... then a Silicon followed by a Germanium Diode...
    So, you don't like the simplicity of that idea....
    One Transistor (BC639 as an example), one 5.6v Zener and a 22K Resistor... ten cents...
    Mar 2004
    UK-Midlands
    Thanks for the replies. Unfortunately the simple diode solution is no use! The Tx and Rx modules need a solid 5v. Any less and their range falls dramatically.
    It seems the easiest solution is to power it from 3 cells use a step up regulator and take a hit on the slightly reduced battery life.
    But thanks again for everyone’s help.
    Bob
  1. 4 pin 4 x 4 keypad interface using pic basic pro
    By dunlao_john in forum mel PIC BASIC Pro
    Last Post: - 15th January 2009, 06:21
  2. problem with my code
    By civicgundam in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2008, 02:52
  3. Microcontroller with 2 way paging application problem
  4. Real Time Clock & Eeprom
    By smart_storm in forum General
    Last Post: - 17th February 2006, 20:03
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
