RB0 + Internal Pullup + Interrupt
Results 1 to 21 of 21
    May 2008
    Question RB0 + Internal Pullup + Interrupt
    Hi again.
    I've got a slight issue with my task.
    I need PortB to have internal pullups on because I'm enhancing an existing board design that relied on them, however - I have an issue with implementing interrupts because RB0 is now high all the time and I need it to be low, I can achieve this by using a pulldown on top of the pullup, but my board space is running low
    Is there a way to set RB0 not to use it's internal pullup?
    Quote Originally Posted by Freman View Post
    Hi again.
    Hi Freman,
    Please tell us which PIC you are using . . .and without knowing that or seeing your board I ask if you have room for one of those SIP resistor ladders for pullups ?
    May 2008
    Sorry, it was stupid of me to forget the pic - it's a PIC16F628A
    And no, I really have no room left for much more on that board, I can probably cram one more resistor in as a pulldown but that's about it.
    Datasheet PP36 sec. 5.2 . . . "A single control bit can turn on ALL THE PULLUPS. . . . The weak pull up is automatically turned off when the port pin is configured as an output." I think you are stuck using the resistor unless you can flip the port's use in the software I E. instead of, if high then to if low then. I have a blinky running right now which toggles the tris on a port and as soon as it goes back to input the wpu is on.
    May 2008
    I think I've found another side effect of using internal pullups...
    I always figured if I couldn't get any other method working for this, I'd fallback to serial/uart communications...
    I can't get the UART working
    I'm using a usb>serial chip, but it's no real matter because both pins 7(RB1/RX) and 8(RB2/TX) are always high
    Any ideas how I can get this working?
    Hi Freeman,
    Gotta see some code. USART Idles high, in normal operation.
    May 2008
    Here's the code
    @     device pic16F628A, hs_osc, wdt_off, pwrt_on, lvp_off, protect_off, bod_on, cpd_off, pwrt_off, mclr_off
    DEFINE OSC 20
    DEFINE PULSIN_MAX 3000
    CMCON        = 7
    VRCON        = 0
    ALL_DIGITAL
    ' Alias our pins
    BEEP           VAR PORTA.0 ' Buzzer
    RFIN           VAR PORTA.1 ' Remote input
    PROXIMITY_DOWN VAR PORTA.2 ' Proximity sensor for DOWN travel
    RELAY1         VAR PORTB.4 ' Relay 1 output
    RELAY2         VAR PORTB.5 ' Relay 2 output
    BUTTONA        VAR PORTB.6 ' Primary panel button input
    BUTTONB        VAR PORTB.7 ' Secondary panel button input
    ' Define some aliases for USART
    OERR           VAR RCSTA.1 ' Over-run bit
    CREN           VAR RCSTA.4 ' Continuous receive enable bit
    RCIF           VAR PIR1.5  ' Received character interrupt flag bit
    DEFINE HSER_RCSTA 90h      ' Receive register to receiver enabled
    DEFINE HSER_TXSTA 20h      ' Transmit register to transmitter enabled
    DEFINE HSER_BAUD 9600      ' Set baud rate
    ' Set the pin directions
    INPUT RFIN
    INPUT BUTTONA
    INPUT BUTTONB
    OUTPUT BEEP
    OUTPUT RELAY1
    OUTPUT RELAY2
    OUTPUT PROXIMITY_DOWN
    ' Configure the output pins as low
    LOW BEEP
    LOW RELAY1
    LOW RELAY2
    LOW PROXIMITY_DOWN
    ' Turn on weak pull-ups
    OPTION_REG.7 = 0
    ' We want to interrupt on the falling edge
    OPTION_REG.6 = 0
    ' Set us up some variables
    PBITS        VAR BYTE[24]  ' The bits we've read
    RAW          VAR WORD      ' The raw pulsin value
    ADDRESS      VAR WORD      ' Storage for the address
    DBYTE        VAR BYTE      ' Storage for the data
    LOOPADDRESS  VAR WORD      ' Second loop storage of first loop addres
    LOOPDBYTE    VAR BYTE      ' Second loop storage of first loop data byte
    X            VAR BYTE      ' Loop/TMP var
    Y            VAR BYTE      ' Loop/TMP var
    STATE        VAR BYTE      ' Current state of the device
    serialbyte   VAR BYTE
    ' Default state
    STATE = STATE_STOPPED
    ON INTERRUPT GOTO sighup
    INTCON = %11010000
    PIE1   = %00100000
    ' Reset all the primary RF variables
    TOP:
        ADDRESS = 0 : RAW = 0 : DBYTE = 0
    MAIN:
        ' Set both buttons for input
        INPUT BUTTONA
        INPUT BUTTONB
        ' Check to see if the individual buttons are toggled
        IF NOT BUTTONA THEN GOSUB subDown
        IF NOT BUTTONB Then GOSUB subUp
        ' Fiddle with the inputs to see if the middle button is pushed
        LOW BUTTONB
        X = BUTTONA ' If it's LOW then there's a good chance the middle button is down
        HIGH BUTTONB
        INPUT BUTTONB
        LOW BUTTONA
        Y = BUTTONB ' If it's LOW then there's a good chance the middle button is down
        HIGH BUTTONA
        INPUT BUTTONB
        INPUT BUTTONA
        IF NOT Y AND NOT X THEN GOSUB subStop ' Both register as LOW then the middle button is down!
        ' Look for one huge low pulse
        PULSIN RFIN, 0, RAW
        ' 2350 is about mean average
        IF RAW < 2340 OR RAW > 2360 THEN MAIN
        ' Read 16 address bits and 8 data bits
        FOR X = 0 TO 23
            PULSIN RFIN, 0, RAW
            ' Check the pulse parameters
            if RAW < 30 OR RAW > 240 THEN MAIN
            PBITS[x] = NCD RAW
        NEXT X
        ' Gather the address
        ADDRESS = 65535 ' Maxmimum known ID
        FOR X = 0 to 15
            IF PBITS[x] > 7 THEN ADDRESS.0[X] = 0
        NEXT X
        ' Gather the data
        DBYTE = 255 ' Maximum known data value
        Y=0
        FOR X = 16 TO 23
            IF PBITS[X] > 7 THEN DBYTE.0[Y] = 0
            Y = Y + 1
        NEXT X
        ' If we've done a loop...
        IF ADDRESS == LOOPADDRESS AND DBYTE == LOOPDBYTE THEN
            SELECT CASE DBYTE
                CASE 3
                    GOSUB subUp
                CASE 12
                    GOSUB subStop
                CASE 192
                    GOSUB subDown
            END SELECT
            LOOPDBYTE = 0
            LOOPADDRESS = 0
            ' Start a loop
            LOOPDBYTE = DBYTE
            LOOPADDRESS = ADDRESS
        GOTO TOP
    DISABLE
    subUp:
        IF STATE != STATE_GOING_UP THEN
            HIGH BEEP             ' Start making noise
            LOW RELAY1            ' Make sure the down relay is off (Don't know what happens otherwise, don't want to know!)
            LOW PROXIMITY_DOWN    ' Turn off the down proximity sensor
            PAUSE BEEP_WAIT       ' Wait a bit
            LOW BEEP              ' STFU :)
            IF STATE.3 != 1 THEN PAUSE POST_BEEP_WAIT
            HIGH RELAY2           ' Turn the up relay on
            STATE = STATE_GOING_UP
            PAUSE WAIT_WAIT
    subStop:
            LOW RELAY1            ' Turn off the down relay
            LOW RELAY2            ' Turn off the up relay
            LOW BEEP              ' STFU :)
            PAUSE WAIT_WAIT
    subDown:
        IF STATE != STATE_GOING_DOWN THEN
            LOW RELAY2            ' Make sure the up relay is off (Don't know what happens otherwise, don't want to know!)
            LOW BEEP              ' STFU :)
            HIGH RELAY1           ' Turn the down relay on
            HIGH PROXIMITY_DOWN     ' Turn on the down proximity sensor
            STATE = STATE_GOING_DOWN
            PAUSE WAIT_WAIT
    sighup:
        X = STATE
        IF INTCON.1 == 1 THEN
            GOSUB subStop
            INTCON.1 = 0
        WHILE RCIF                                 ' While there are bytes to be read
            serialByte = RCREG                    ' Read a byte
            HSEROUT [1, serialByte] ' Tell the sender what byte was received
            IF serialByte = 117 THEN GOSUB subUp
            IF serialByte = 100 THEN GOSUB subDown
        WEND
        IF OERR = 1 THEN
            CREN = 0
            CREN = 1
        RESUME
    ENABLE
    Specifically of interest I guess is this bit - the fiddling with buttons bit
        INPUT BUTTONA
        INPUT BUTTONB
        LOW BUTTONB
        HIGH BUTTONB
        INPUT BUTTONB
        LOW BUTTONA
        HIGH BUTTONA
        INPUT BUTTONB
        INPUT BUTTONA
    And here is the basic schematic.
    I'm looking for any solution, hardware or software - I can't change the bit in the unchangeable box, that's the existing pcb that I'm upgrading...
    I do not see the TX or RX connected to anything??
    But... using http://www.picbasic.co.uk/forum/show...24&postcount=4
    PIC MULTICALC the setting should be
    DEFINE HSER_SPBRG 129 ' 9600 Baud @ 20MHz, 0.16%
    May 2008
    No, in that schematic they're not connected to anything - but in reality they're hooked up to tx and rx of a usb-serial adapter. The schematic I posted was more to illustrate the reason behind the pullups being turned on.
    The serial values I'm using are ones I've used in another project that's working... but I'll give yours a try.
    Edit.
    Nope, no change...
    I have noticed tho that when I send data over the usb/serial cable that the voltage does in deed dip (drops from 4.95 to 4.60v) which indicates that the signal is being transmitted (my multimeter isn't fast enough to measure the full weight of the dip)
    I've also done some testing on the usb/serial cable and have found it goes to 3v when high (again probably more, my multimeter can't keep up)
    May 2008
    Oh dear - I feel stupid now...
    I souldered the tx wire to dtr...
    Never fear tho - I've had my eyesight checked, and the idiot that left me in charge has been taken out the back and flogged
    May 2008
    Which has left me with another problem...
    The pic isn't recieving my strings right...
    d and u are what I'm sending, d consistently returns v... don't know what u returns...
    v returns 7, 7 makes the screen work in place of d
    I always blame my bifocals when something like that happens
    Your other problem... I will assume the 232 chip or equivalent is working and the settings on the machine sending the data are correct? I do not know what would cause the problem...
    You really want 2 PWRT statements here ?
    Shouldn't you clear RCIF in your int handler ?
    May 2008
    Umm, well... I don't understand the header... I sort of found one that worked and stuck with it
    Doesn't reading from RCIF clear it?
    Doesn't a while statement read it?
    I'm using a pl2303 chip mounted on a basic board (get them on ebay from china for $6 a pop, strip them down, cheaper then buying the individual components and you get spare parts)
    Don't honestly know if they work right, they pass a loop back test - I'd probably need to pay a visit to my local electronics store and grab a null modem or equiv cable (Don't have any female 9pin plugs...) to test them properly - don't have any other serial ports in the house to use...
    I've done some more scientific testing then firing random characters at the thing and seeing what it gives me back...
       DEBUG: Initializing
            DEBUG: Creating lockfile for /dev/ttyUSB2
            DEBUG: Opening serial port /dev/ttyUSB2
          DEBUG: Setting port configuration
            DEBUG: Writing settings
       DEBUG: Initialized
     DEBUG: Screen up
       DEBUG: Transmitting
          DEBUG: Sending: 00000001
         DEBUG: Sent 1 bytes
       DEBUG: Receiving
         DEBUG: Waiting for 4 bytes
         DEBUG: Received 4 bytes
          DEBUG: Received: 00000000,01010101,01010101,01111111
       DEBUG: Receive OK
    DEBUG: Transmit Failed
    So what I've done here is written a script that sends 0x01 to the pic, the pic is supposed to send back 0x55, 0x55, 0x01 0x01
    The 0x55, 0x55, 0x01 is hardcoded, the second 0x01 is what it's received from the wire. (the 0x55 was chosen because it represents alternating 0's and 1's helps detect squishing bitrates)
    What I'm getting back is 0x00, 0x55, 0x55, 0x7f, and it's consistent...
    If I ask my script to read more bytes it reads back a maximum number of 5 - 00000000,01010101,01010101,01111111,01000000
    If I send something different say, 0x7F I get back 00000000,01010101,01010101,01111111,00000001
    0x02 00000000,01010101,01010101,01111111,01100000
    0x03 00000000,01010101,01010101,01111111,00100000
    0x04 00000000,01010101,01010101,01111111,01110000
    So here, I made it output 0x00 - 0xff, 0x01, 0x04 - which should be 258 bytes, but I got back 252. so there's at least 6 missing bytes, and it appears to be talking to me inverted off by a bit...
    00000000,11111101,11111011,11111001,11110111,11110 101,11110011,11110001,11101111,11101101,11101011,1 1101001,11100111,11100101,11100011,11100001,110111 11,11011101,11011011,11011001,11010111,11010101,11 010011,11010001,11001111,11001101,11001011,1100100 1,11000111,11000101,11000011,11000001,10111111,101 11101,10111011,10111001,10110111,10110101,10110011 ,10110001,10101111,10101101,10101011,10101001,1010 0111,10100101,10100011,10100001,10011111,10011101, 10011011,10011001,10010111,10010101,10010011,10010 001,10001111,10001101,10001011,10001001,10000111,1 0000101,10000011,10000001,01111111,01111101,011110 11,01111001,01110111,01110101,01110011,01110001,01 101111,01101101,01101011,01101001,01100111,0110010 1,01100011,01100001,01011111,01011101,01011011,010 11001,01010111,01010101,01010011,01010001,01001111 ,01001101,01001011,01001001,01000111,01000101,0100 0011,01000001,00111111,00111101,00111011,00111001, 00110111,00110101,00110011,00110001,00101111,00101 101,00101011,00101001,00100111,00100101,00100011,0 0100001,00011111,00011101,00011011,00011001,000101 11,00010101,00010011,00010001,00001111,00001101,00 001011,00001001,00000111,00000101,00000011,0000000 1,11111111,00111111,10011111,11101110,11101010,111 00110,11100010,11011110,11011010,11010110,11010010 ,11001110,11001010,11000110,11000010,10111110,1011 1010,10110110,10110010,10101110,10101010,10100110, 10100010,10011110,10011010,10010110,10010010,10001 110,10001010,10000110,10000010,01111110,01111010,0 1110110,01110010,01101110,01101010,01100110,011000 10,01011110,01011010,01010110,01010010,01001110,01 001010,01000110,01000010,00111110,00111010,0011011 0,00110010,00101110,00101010,00100110,00100010,000 11110,00011010,00010110,00010010,00001110,00001010 ,00000110,00000010,11111110,00011111,10001111,1101 1100,11010100,11001100,11000100,10111100,10110100, 10101100,10100100,10011100,10010100,10001100,10000 100,01111100,01110100,01101100,01100100,01011100,0 1010100,01001100,01000100,00111100,00110100,001011 00,00100100,00011100,00010100,00001100,00000100,11 111100,00001111,10000111,10111000,10101000,1001100 0,10001000,01111000,01101000,01011000,01001000,001 11000,00101000,00011000,00001000,11111000,00000111 ,10000011,01110000,01010000,00110000,00010000,1111 0000,00000011,10000001,11100000,00000001,10000000, 01111111,01110000
    That's a honest answer!
    Here is My honest answer, probably does, I do not know for sure if it does, or not, that is why I said it as a question
    May 2008
    I've had a look at the datasheet for the pic, and it states
    "Flag bit RCIF is a read-only bit, which is cleared by the hardware. It is cleared when the RCREG register has been read and is empty."
    So the WHILE isn't actually resetting it, reading RCREG is.
    I also found the datasheet for the PL-2303, it rx's at TTL (5v levels) and tx's at 3.3v - so that's some concrete information, but doesn't really help with what seems like inversion...
    May 2008
    I've just finished testing the USB-Serial cable, and it appears to be working.
    I've hooked it up TX-RX, RX-TX, GND-GND to a PC serial port (Real hardware kind) and I can send and recieve data to and from the device without any form of corruption.
    Which brings me back to my original query... are the pullup's in the PIC breaking my serial communications?
    If so, can anyone come up with a simple way to re-do the input detection of the buttons? (I have spare pins on the pic if that helps )
    Edit:
    Actually I think I found the answer to my problem "The HW USART output is inverted as it is designed to work with an RS232 driver." that means I must have built my FT232 circuit to use the inverted output/input (the FT232 chip is very smart, I just don't remember doing that...) I haven't been using a max232 chip on this project because the voltages were within tolerance, and I just don't have the room... maybe I'll have to build an external serial adapter...
    Edit:
    Hi Freman,
    I have never used HSEROUT . HSERIN requires you to send data to it TRUE, and idles in the HIGH state. This from the data sheet . . . <b>
    "The USART’s transmitter and receiver are functionally
    independent but use the same data format and baud rate." </b>
    and this:
    <b> "Clearing enable bit TXEN during a transmission will cause the
    transmission to be aborted and will Reset the
    transmitter. As a result the RB2/TX/CK pin will revert to
    hi-impedance."</b>
    This suggests to me it transmits TRUE too. Fact is I do not know, but the evidence suggests it.
    I think that solves it. Look at the PBP manual.
    Install an inverter as the manual states when using hardware serial or change your code to software, SERIN2/SEROUT2, and get back with us.
    May 2008
    *sigh* Just another one of the things that leave me asking WTF were they thinking when they designed these chips... oh well..
    I bet they had a good reason.... Who knows what it was. Might be that a 232 type chip can bring the levels up to true RS232 levels that a micro can not because of the voltage they run at.
    Most times the software solution will work and you then have the benifit of using most any pin. About the only time I use hardware (HSERIN/OUT) is if I need it running in the background as in an interrupt. Of course if something else triggers the interrupt then you can have the software routine in that interrupt.
    All kinds of possibilities.
  1. Can't ID interrupt source with this IntHandler??
  2. RB0 interrupt problems
    By amindzo in forum General
    Last Post: - 26th August 2006, 12:52
  3. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 03:59
  4. Interrupt Problem
    Last Post: - 16th November 2005, 21:58
