PBP 2.6/MPLab 8.33 ASM "COD" error message
Results 1 to 10 of 10
    FutureFAE's Avatar
    FutureFAE Guest
    Default Not working in Vista
    The PBPMPLAB.BAT file does not seem to want to run, even when run as administrator.
    The error message is as follows for running the "Install MPLAB plugin":
    "The module "C:\PBPDEMO\PBPSUITE.DLL" faild to load. Make sure the binary is stored at the specified path or debug it to check for problems with the binary or dependant .DLL files. The application has fialed to start because it's side-by-side configuration is incorrect. Please see the applicaiton ecent log for more detail."
    When I tried to run it from the command line, I get:
    "The module "PBPSUITE.DLL" was loaded but the call to DllRegisterServer failed to load with error code 0x80070005. For more information about this problem, search online using the error code as a search term."
    The configuration I was trying to run was MPLAB 8.36, and PBP v2.60, and windows Vista Home Premium.
    It looks like it's pointing to an old Demo version of PBP.
    Try the instructions to the right of the first image on this page ...
    http://www.melabs.com/support/mplab.htm
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. PBP, ASM and LST files
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 12th January 2010, 14:43
  3. ASM or PBP First?
    By mackrackit in forum Off Topic
    Last Post: - 10th October 2009, 13:08
  4. pbp - asm variable passing
    Last Post: - 25th May 2009, 09:49
  5. asm and pbp
    By pic beginner in forum mel PIC BASIC Pro
    Last Post: - 24th October 2004, 06:33
