New to PIC
Results 1 to 21 of 21
Thread: New to PIC
    Jul 2009
    Ohio, USA
    Ok so I got the PICBasic pro compiler today and am having trouble with PORTA on the PIC18F1320.
    I have 6 charlieplexed leds on Porta.0, Porta.6 and Porta.7 as seen here http://www.blueroomelectronics.com/d...structions.pdf
    I cannot get a led to light on PORT6 or 7
    Here is my code
    ADCON1 = 127
    input porta.7
    led var porta.0
    sink var porta.6
    low sink
    loop:
    pause 5
    toggle led
    pause 5
    toggle sink
    goto loop
    Hi Mike, Welcome to the forum. You have analog stuff to turn off on PortA.
    ADCON0 = 0 'disable A/D module disabled
    ADCON1 = 127 'AN1 through AN6 as digital
    Hmmm no CMCON or CMCON0 . . . . still looking . . . .
    Ok now I looked at the Data sheet on the junebug. PortA is used as outputs, so let's start here:
    DEFINE OSC 4 ' or some other number as fits you
    PortA = %00000000 ' a zero for each pin drives LATA registers all low so when made an output they will all be @ ground
    TRISA = %00000000 ' All portA pins as outputs
    PortA = %10000001 , Light 1 on
    Pause 200
    TRISA.7 = 1 ' Tristates PortA.7
    PortA = %01000000 'Light2 on
    pause 200
    TRISA = %00000001 ' Tristates RA0
    portA = %01000000 ' Light3 on
    and so on, here is untested code
    Different methods shown above.
    A better way might be to use 2 lookup tables and a for next loop to display this somewhat unusual LED Array.
    TrisVar Var Byte
    PortVar Var Byte
    index   Var Byte
        For index = 0 to 5
            lookup index,[%00000000,%00000000,%00000001,%00000001,%01000000,%01000000], TrisVar
            lookup index,[%00000001,%01000000,%01000000,%10000000,%10000000,%00000001], PortVar
            PortA = PortVar
            TrisA = TrisVar
            Pause 200
        next index
    GoTo Main
    Jun 2006
    You need to set internal oscillator because you use porta.6 and porta.7 as I/O.
    See page 17 on datasheet of pic18f1230.
    Jul 2009
    Ohio, USA
    Thanks for the input guys, still no luck with the program, maybe its the Junebug... I don't know. Any other suggestions?
    If you think it might be the "June bug" try a simple hardware setup with one LED on a non analog pine and see it you can make it blink.
    Jul 2009
    Ohio, USA
    I can get the other ports to respond to programming but PORTA.6 and 7 don't do as they should.
    Quote Originally Posted by Mike2545 View Post
    OK, that rules out the "junebug".
    Can you post your current code, configs, and schematic so we can take a look?
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  2. Replies: 67
    Last Post: - 8th December 2009, 03:27
  3. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 15:46
  4. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
