New to PIC
Results 1 to 21 of 21
Thread: New to PIC
    Jul 2009
    Ohio, USA
    Default New to PIC
    Hello, I have been using the Basic Stamp for a few projects and have just recently purchased the PicBasic Pro Compiler. I was wondering if I would also need the MicroCode studio Plus or does that come with the software above.
    I am awaiting delivery soon and can't wait to start programming PICs.
    Mike2545
    The free version of MCS that comes with PBP is good enough. The CD will also have MPLAB that you may also like.
    Every thing you need to write and compile code comes on the CD.
    Welcome to the world of PICs.
    Jul 2009
    Ohio, USA
    Thanks for the info. Do you know if I will be able to use a 'JuneBug' for a programmer?
    Not sure. But if it can take a HEX file and send it to the PIC then it should. Does it come with software?
    Jul 2009
    Ohio, USA
    No software, but I can use MPLAB/swordfish to program it so...it should work.
    I will know when I get the package.
    Jul 2009
    Ohio, USA
    Ok so I got the PICBasic pro compiler today and am having trouble with PORTA on the PIC18F1320.
    I have 6 charlieplexed leds on Porta.0, Porta.6 and Porta.7 as seen here http://www.blueroomelectronics.com/d...structions.pdf
    I cannot get a led to light on PORT6 or 7
    Here is my code
    ADCON1 = 127
    input porta.7
    led var porta.0
    sink var porta.6
    low sink
    loop:
    pause 5
    toggle led
    pause 5
    toggle sink
    goto loop
    Hi Mike, Welcome to the forum. You have analog stuff to turn off on PortA.
    ADCON0 = 0 'disable A/D module disabled
    ADCON1 = 127 'AN1 through AN6 as digital
    Hmmm no CMCON or CMCON0 . . . . still looking . . . .
    Ok now I looked at the Data sheet on the junebug. PortA is used as outputs, so let's start here:
    DEFINE OSC 4 ' or some other number as fits you
    PortA = %00000000 ' a zero for each pin drives LATA registers all low so when made an output they will all be @ ground
    TRISA = %00000000 ' All portA pins as outputs
    PortA = %10000001 , Light 1 on
    Pause 200
    TRISA.7 = 1 ' Tristates PortA.7
    PortA = %01000000 'Light2 on
    pause 200
    TRISA = %00000001 ' Tristates RA0
    portA = %01000000 ' Light3 on
    and so on, here is untested code
    Different methods shown above.
    A better way might be to use 2 lookup tables and a for next loop to display this somewhat unusual LED Array.
    TrisVar Var Byte
    PortVar Var Byte
    index   Var Byte
        For index = 0 to 5
            lookup index,[%00000000,%00000000,%00000001,%00000001,%01000000,%01000000], TrisVar
            lookup index,[%00000001,%01000000,%01000000,%10000000,%10000000,%00000001], PortVar
            PortA = PortVar
            TrisA = TrisVar
            Pause 200
        next index
    GoTo Main
    Jun 2006
    You need to set internal oscillator because you use porta.6 and porta.7 as I/O.
    See page 17 on datasheet of pic18f1230.
    Jul 2009
    Ohio, USA
    Thanks for the input guys, still no luck with the program, maybe its the Junebug... I don't know. Any other suggestions?
    If you think it might be the "June bug" try a simple hardware setup with one LED on a non analog pine and see it you can make it blink.
    Jul 2009
    Ohio, USA
    I can get the other ports to respond to programming but PORTA.6 and 7 don't do as they should.
    Quote Originally Posted by Mike2545 View Post
    OK, that rules out the "junebug".
    Can you post your current code, configs, and schematic so we can take a look?
    Jul 2009
    Ohio, USA
    Here is my code, it flashes leds on PORTA.0 and PORTB.0
    ADCON0 = 0
    ADCON1= 127
    define OSC 4
    led var PORTA.0
    sink var PORTB.0
    loop:
    toggle PORTA.6
    pause 5
    high led
    pause 5
    low led
    pause 5
    high sink
    pause 5
    low sink
    goto loop
    PORTA.6 is just low, it does not toggle or go High if I change the code.
    The schematic is simple, I connected VPP, +5, Gnd, PGD and PGC.
    I have 470 ohm resistors from the PIC to leds connected to GND.
    Could it be the clock output function? How do I set INTRC_OSC_NOCLKOUT?
    The above talks about how to set the configs.
    You can do it in your code or just modify the PICs *.inc file.
    Jul 2009
    Ohio, USA
    Well, nothing I have tried with this has worked, I can get it to work in Swordfish Basic but Microcode studio is not what I expected for the Price they charge.
    Has anyone else gotten a 18F1320 to work correctly with PICBasic Pro?
    I am beginning to regret shelling out good money for a product that does not work as well as a free compiler.
    Did you get the OSC set correctly ?
    Post you config settings.
    Jul 2006
    Hi Mike,
    I was reading through this thread and it looked like something Savnik pointed out might not be too clear. (But very correct.)
    Porta.6 and a.7 are reserved for an external oscillator, so they can't be used as regular pins unless you put a config line in PicBasic Pro to explicitly enable them as pins. That's probably why the other LEDs work, but those don't.
    Since I don't know anything about Swordfish, I can't compare how it does this. For me, once I started understanding the setting of fuses, things started getting smoother.
    Hang in there. I find PicBasic Pro to be very powerful. So far, whenever something doesn't go as planned, it is just a little thing I haven't learned yet.
    Jul 2009
    Ohio, USA
    OK, I got the OSC set with OSCCON =$60 so its not running at 37khz anymore, which makes sense that the pause statements were way too fast for the result I was getting; pause 5 is way too small for what I was used to in basic, now pause 500 is more like it.
    As for setting the fuses, I think I will need help figuring out how to do that.
    Mike2545
    Mike2545
    First off read the thread I linked to above. Then let's just change the configs in the Inc file. If you were going to change things often then doing it in code is handy.
    Go to the PBP directory and find the Inc file with your chips name. There you will see the config settings. You may want to male a backup of the file.
    Then go to the MPASM directory in program files and find the coorosponding Inc there. The microchip Inc near the end has all of the possible settings.
    Change the PBP Inc to the way you want it.
    I am on my phone at the moment so I can not show the exact change.
    Jul 2009
    Ohio, USA
    Yep, that did it!!
    I just needed to find the .Inc files...On my C: drive (That bit of info might have been helpful)
    Anyway, I am glad to have solved this, first of many, I'm sure, issue.
    Thanks for your help.
    Mike2545
    I thought that info was in the other thread?
    Oh well , glad you got it going.
    Read you later. Have fun!
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 10:00
  2. Replies: 67
    Last Post: - 8th December 2009, 02:27
  3. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 14:46
  4. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
    Last Post: - 11th March 2005, 23:14
