Simple Maths Going Wrong
Results 1 to 40 of 44
    Miami, Florida USA
    Very nice animated simulation by DT. What program are you using to create this?
    Now, in DT's posted program taking an average with "S=(S*(AvgCount-1)+Temp)/AvgCount" takes some time to converge. With sudden changes in wind direction, which is usually the case, a high sampling rate is needed to keep up with this algorithm. This is a common issue when averaging several readings.
    Bill,
    After more testing, I can say that the problem I was seeing was due to my averaging the circular buffer after each sample.
    By taking 16 samples (at high speed) then averaging, the vane can never go more than 128 unless it's crossing zero and everything works fine. If the samples are slow enough that the vane can go more than 128, the problem shows up again.
    I'm sticking with SIN/COS/ATN.<hr>
    The program I'm using is DT_InstruMental. Something I've been working on for awhile that makes it easy to display info from the PIC graphically.
    It's still in it's infancy, but the only way to figure out what I need to do with it, is to use it. ... So I'm using it.
    Here's one of my favorites so far ...
    <object id='stUkhdQ01IR11XRl9VWV1aVF5T' width='345' height='308' type='application/x-shockwave-flash' data='http://www.screentoaster.com/swf/STPlayer.swf' codebase='http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,115,0'><param name='movie' value='http://www.screentoaster.com/swf/STPlayer.swf'/><param name='allowFullScreen' value='true'/><param name='allowScriptAccess' value='always'/><param name='flashvars' value='video=stUkhdQ01IR11XRl9VWV1aVF5T'/></object>
    It is what I 've been dreaming!
    Can I have it?
    NO! You can't have my KEG of beer.
    Oh, you meant the program ...
    I hope that everyone will have it someday, some kind of shareware/crippleware/demo, don't know yet.
    But right now, you would hate me for the grief you would endure.
    It really needs to be more user friendly, which is why I'm trying to use it as much as possible, so I can figure out the best way to go.
    Before anyone gets it .. It must BE a dream, not a nighmare.
    Nov 2007
    South-West of Australia. A small town called Denmark. 'Where the forest meets the sea.'
    Default Vectors
    DT,
    I used StampPlot from Selmaware for a PID motor control demonstration last year, thoughts on it ~ may be of some interest in your development?
    1. Fantastic that I could produce a PC interface without learning Visual Basic.
    2. I think it was free, or I paid a very small amount of $ for the improved graphic design function.
    3. The complexity of the commands was OK once you had an example to modify ~ working with the User Guide alone was, in some cases, very difficult.
    4. The supplied controls, whilst functionally good, were visually poor ~ I imagined they were modelled on instruments in a Soviet 1950 power station.
    5. I would have been prepared to pay more for a better product that had the benefit of lots of polishing.
    6. However, excellent value for the very low cost ~ a labour of love for the developer.
    Regards Bill Legge
    PS Any recomendations for a book on learn Visual Basic?
    Miami, Florida USA
    Bill,
    Take a look at this software
    http://www.abacom-online.de/uk/html/...ab-expert.html
    I haven't used it yet but it looks like it would do the job. Has anybody used it?
    May 2007
    Republic Serbia
    Thumbs up
    Bill,
    Here is I use it and is very good.
    My scope project.
    Mar 2009
    Colorado
    Default StampPlot with USB interface to PIC 18F4550??
    Quote Originally Posted by Bill Legge View Post
    DT,
    Regards Bill Legge
    Bill, I also am trying to get an application going without having to use VB6. I need to interface a laptop computer to an 18F4550 based microcontroller via USB to read the data stored by the 18F4550 in its EEPROM over a 31 day period [93 bytes = 31 daily measurements x (date value, Data_LSB, Data_MSB) ] . I need the data to be inserted on the PC side into an Excel spreadsheet for plotting and analysis purposes by the user. It appears that StampPlot might be a candidate to do this, but it appears it really only works with BasicStamp and RS232 or serial interfaces and not USB. As a user of StampPlot can you advise me if I can adapt it to use for USB and PICBASICPro without a huge learning curve? My controller is done and my project has a short fuse so can't spend a lot of learning time to get the PC side and USB interface going Would really appreciate your advice!~
    Nov 2007
    Default Stamp Plot Pro
    Jellis,
    I thought this thread was long dead! My thoughts on PIC/USB/StampPlotPro:
    1. StampPlotPro won't talk USB.
    2. I don't know enough about USB comms to know how one would 'change' an incoming USB data stream, inside the laptop, to get it to talk to StampPlotPro.
    I've now modified my weather station to record CSV files on a thumb drive by using a Vdrive2 module from Vinculum - about $50 - and transfer the data about once a month. However, this does not solve your need to get a 'real time display.'
    I expect there must be some 'easy to customise' softwear for a PC that talks USB and gives a virtual instrument panel.
    I keep putting off starting to learn VB. I'm told that it's quite easy? Thoughts on StampPlotPro:
    1. Fast and easy to cobble displays together.
    2. Documentation is pretty good.
    3. I paid the extra ($20 I think?) for the add on bits - worth it.
    4. The graphics are a bit '1950 Soviet power station' style - but you can add your own.
    Sorry to be of little/no help to you. If you solve it, please let me know how.
    Regards Bill Legge
    Of course not! If I drink half of glass thenfor the rest of the day I 'll keep singing. And trust me, I am really bad singer!
    About the software, I have no problem with the way you are going to distribute it, as long as I do not have to learn Visual $omething.
    Feb 2008
    Michigan, USA
    Default DT_InstruMental
    Sorry Internet Explorer only.
    It displays fine on Firefox 3.0.12 here.
    Bo
    Quote Originally Posted by boroko View Post
    Bo
    OH! Great, thanks.
    It must be my very old installation of FirFox that I never use.
    I should update it I suppose.
  1. Simple RF remote control code
    Last Post: - 22nd January 2014, 11:45
  2. Simple Blinking LED - WTF!!
    By johnnylynx in forum mel PIC BASIC Pro
    Last Post: - 1st February 2010, 07:19
  3. Simple LCD code not working!...WHY?
    Last Post: - 29th November 2009, 20:48
  4. what's wrong 16F877A simple code?
    Last Post: - 30th October 2009, 02:11
  5. Doing Simple Math - getting the wrong answer
    Last Post: - 8th March 2005, 15:27
