Simple Maths Going Wrong
Results 1 to 40 of 44
    May 2008
    Italy
    Darell, I think that the problem given in post one still remain even with adding 1/10 of the variation (with your smooting system) because the variation are so big (1 to 255) that will making swinging also your reading if not filtered.
    As far this new release of PBP 2.6 is concerned can you please clearify this trigonometric manipulation:
    Wind = (C-127) ATN (S-127) = cos(a) (no math sign ?) ATN sin(a)
    I know that tan(a) = sin(a)/cos(a) so (a) = atn (sin(a)/cos(a))
    Is this the way that the new PBP use to extract the angle?
    Thank you for your help in understanding.
    Al.
    Hmm, I don't know Bill.
    I've had a play with your code, and I'm not sure about it.
    It does seem to pick a valid point in-between two samples. But it only averages that point, and the previous point found between two other samples. It's not averaging all the samples, so it's still very jumpy.
    Your explanation describes EEPROM locations up to 29, but there are only 15 DATA values, although I don't think that affects the problem.
    I've modified the program a bit to use the Average as the X value, then read the samples one at a time, also connected a POT to simulate the wind vane, but I get the same results.
    Another hiccup, if the average is currently 10, then it receives a string of 255 samples, it stops at 1, and never crosses 0. And for many other samples, it stops 1 number away from the actual reading. 250 might stop at 249 or 251.
    I think finding a point in-between 2 samples is fairly easy. But averaging a large number of samples is something altogether different, and a 2-sample average just doesn't do it.
    Aratti,
    The ATN function is actually an ATAN2 type since it works for all four quadrants. An arctangent would only work with 1 quadrant.
    The format of the statement is ...
    Result = X ATN Y
    There aren't any other "math signs" involved.
    Nov 2007
    South-West of Australia. A small town called Denmark. 'Where the forest meets the sea.'
    Default Simple Maths
    DT. Thanks for taking time to look into the code.
    First, I wrote it specifically to average 16 samples - it won't work with any other number because of the counter:
    J/2 + 16
    This counter takes the average (or average+128 if the two sample are more that 128 apart - and checks for a 'roll-over' above 255) and stores them:
    Samples 0 and 1 average stored in address 16
    Samples 2 and 3 average stored in address 17
    Samples 4 and 5 average stored in address 18
    Samples 6 and 7 average stored in address 19
    Samples 8 and 9 average stored in address 20
    Samples 10 and 11 average stored in address 21
    Samples 12 and 13 average stored in address 22
    Samples 14 and 15 average stored in address 23
    Then, the same J/2 + 16 deals with the next round of averages:
    Averages of 16 and 17 stored in address 24
    Averages of 18 and 19 stored in address 25
    Averages of 20 and 21 stored in address 26
    Avergaes of 22 and 23 stored in address 27
    And again
    Averages of 24 and 25 stored in address 28
    Averages of 26 and 27 stored in address 29
    And finally
    Averages of 28 and 29 stored in address 30
    I guess the same could be done for other numbers of samples but 16 seems a reasonable number for wind direction and the code is short and simple. I have spent a laborious few hours with a pocket calculator checking the results - and so far it is Ok. If you, or anyone else spots an error please let me know.
    Regards Bill Legge
    WOW! I really got that interpretation wrong didn't I?
    OK, I think I understand what you're doing.
    I'll play with that a bit and see what happens.
    Thanks for explaining.
    I'm thinking you might have a winner there Bill.
    But I have a question or two.
    I've had another go at your code and am getting some promising results.
    It's hard to follow with a calculator, so I made an interface to help test the routines.
    Also, instead of reading/writing to EEPROM, I've modified your routine to use an array, so that I can pass it data from the PC.
    The array is a circular buffer that overwrites the oldest value with the new sample, and on each iteration runs your code to average all 16 samples in the array.
    I'm thinking that the circular buffer might be a problem.
    Maybe if it only took 16 samples then averaged ???
    The modified routine looks like this ...
    X  VAR BYTE                ' First vector
    Y  VAR BYTE                ' Second vector
    Difference  VAR BYTE     ' Difference between vectors, always +
    Average  VAR WORD      ' Average of two vectors
    J  VAR BYTE                ' EEPROM memory address
    BillsData  VAR BYTE[32]
    DataPos    VAR BYTE
    Bill_Avg:
      DataPos = DataPos + 1
      IF DataPos = 16 THEN DataPos = 0
      BillsData(DataPos) = DIR
    ;DATA 250,230,240,34,200,10,10,23,23,21,125,0,34,255,123  ' 16 vectors
      FOR J = 0 TO 28 STEP 2	' Read pairs of vectors
    ;   READ J,  X
        X = BillsData(J)
    ;   READ J+1,Y
        Y = BillsData(J+1)
      	if Y>X THEN SWAP X,Y	' X is always the larger variable
      	Difference	= X-Y
      	Average	= (Difference/2) + Y' Half difference and add to smaller vector
      	IF Difference>128 then
      	Average=Average+128	' Reverse direction of vector
      	IF Average>255 THEN Average=Average-255	' Whole revolution? Subtract 255 if necessary
    ;    WRITE J/2 + 16,Average
            BillsData(J/2 + 16) = Average
      NEXT J
    	Bill_Value = Average
    ;	LCDOUT $fe,$80,"Average: ",DEC3 Average
    The interface simply sends the Wind Vane readings to the PIC where it runs both of our averaging codes, and sends the results back for display.
    Yours is on the right. Any thoughts on the sample buffer?
    It works great unless there are large fast changes. (click image to play)
    <object id='stUkhdQ01IR11XRFVbWlleU19R' width='711' height='444' type='application/x-shockwave-flash' data='http://www.screentoaster.com/swf/STPlayer.swf' codebase='http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,115,0'><param name='movie' value='http://www.screentoaster.com/swf/STPlayer.swf'/><param name='allowFullScreen' value='true'/><param name='allowScriptAccess' value='always'/><param name='flashvars' value='video=stUkhdQ01IR11XRFVbWlleU19R'/></object>
    Sorry Internet Explorer only.
    Nov 2007
    Default Vector Averaging
    Darrel,
    Thanks again for your investigation. The display 'InstruMental' is really good.
    I guess the issue of:
    1. Adding one new vector and then running the 'Averaging Tree' with 15 older vectors. Or...
    2. Waiting till 16 new vectors are available and then running the 'Averaging Tree'
    Is one of latency. And the selection should be based on:
    1. The importance of immediate results.
    2. The time interval between the availability of new vectors.
    3. The need for the MCU to do other things.
    I have attached some code that I used to send the averages to my PC with the screen presentation laid out so one can easily see, and check, the averages. The vectors come from a RANDOM function that loads up the PIC EEPROM. RS232 at 19,200 Baud on pin C.6. Loops continuosely.
    Two questions for you please:
    1. How does one post PBP code here so that it looks neat/tidy. My code looks OK on my PC but when I post it here it is a mess?
    2. Is your 'InstruMental' writtern in Visual Basic? I want to learn this and recently got the book 'VISUAL BASIC FOR ELECTRONICS ENGINEERING APPLICATIONS' by Vincent Himpe. For me (An ex-electronics engineer) it's no good - starts off too advanced. Any advice on a good 'entry level' book?
    Regards Bill Legge
    ' -----[ Title ]-------------------------------------------------
    ' File...... WVL 877 VERTOR AVERAGE
    ' Purpose... Experiment with PIC16F877A
    ' Date...... July 2009
    ' -----[ Program Description ]---------------------------
    ' 1. Devices used:  PIC16F877A on EasyPIC5
    ' ----[ Includes / Defines ]-----------------------------------------
    define OSC 20               ' Define Xtal as 20 MHz.  Use "HS" for programming
    include "modedefs.bas"      ' Include serout defines
    ' -----[ Initialization ]--------------------------------------------
    ADCON1	= %00001110			' A0 is analog, remainder digital
    CMCON	= %00000111			' Comparators OFF
    INTCON	= $80				' Turns off interrupts.  See PBP page 187
    TRISA	= %00000001			' A0 is A/D input
    TRISB=0 : TRISC=0 : TRISD=0 : TRISE=0
    PORTA=0 : PORTB=0 : PORTC=0 : PORTD=0 : PORTE=0
    ' ----[ Variables ]--------------------------------------------------
    X			VAR BYTE		' First vector READ
    Y			VAR byte		' Second vector READ
    Vector		var	byte[31]	' Stores 16 A/D readings of wind direction and averages
    Difference	var	byte		' Difference between vectors, always +
    Average		var	word		' Average of two vectors
    J			var	byte		' EEPROM memory address
    K			var	word
    Memory		var	byte		' Contents of EEPROM address J
    TxPin		var	PORTC.6
    Heartbeat	var	PORTC.0
    '-----[ Main ]-------------------------------------------------------
    	for J = 0 to 15									' Create 16 random numbers 1 to 255
    		random K
    		write J, K.lowbyte							' Load EEPROM with random numbers
    	next J
    	for J = 0 to 28 step 2							' Read pairs of vectors
    		read J,  X
    		read J+1,Y
    		if Y>X then swap X,Y						' X is always the larger variable
    		Difference	= X-Y
    		Average	= (Difference/2) + Y				' Half difference and add to smaller vector
    		IF DIFFERENCE>128 then
    		if Average>255 then Average=Average-255		' Whole revolution? Subtract 255 if necessary
    	    write J/2 + 16,Average
    	next J
    	for J = 0 to 30									' Send to PC at 19,200 Baud
    		read J, Vector[J]
    	next J
    	serout2 TxPin,32,["VECTOR ADDITION",13,13]
    	serout2 TxPin,32,[dec3 Vector[0],9,dec3 Vector[16],9,dec3 Vector[24],9,dec3 Vector[28],9,dec3 Vector[30],13]
    	serout2 TxPin,32,[dec3 Vector[1],13]
    	serout2 TxPin,32,[dec3 Vector[2],9,dec3 Vector[17],13]
    	serout2 TxPin,32,[dec3 Vector[3],13]
    	serout2 TxPin,32,[dec3 Vector[4],9,dec3 Vector[18],9,dec3 Vector[25],13]
    	serout2 TxPin,32,[dec3 Vector[5],13]
    	serout2 TxPin,32,[dec3 Vector[6],9,dec3 Vector[19],13]
    	serout2 TxPin,32,[dec3 Vector[7],13]
    	serout2 TxPin,32,[dec3 Vector[8],9,dec3 Vector[20],9,dec3 Vector[26],9,dec3 Vector[29],13]
    	serout2 TxPin,32,[dec3 Vector[9],13]
    	serout2 TxPin,32,[dec3 Vector[10],9,dec3 Vector[21],13]
    	serout2 TxPin,32,[dec3 Vector[11],13]
    	serout2 TxPin,32,[dec3 Vector[12],9,dec3 Vector[22],9,dec3 Vector[27],13]
    	serout2 TxPin,32,[dec3 Vector[13],13]
    	serout2 TxPin,32,[dec3 Vector[14],9,dec3 Vector[23],13]
    	serout2 TxPin,32,[dec3 Vector[15],13,13,13]
    	goto Main
    Miami, Florida USA
    Very nice animated simulation by DT. What program are you using to create this?
    Now, in DT's posted program taking an average with "S=(S*(AvgCount-1)+Temp)/AvgCount" takes some time to converge. With sudden changes in wind direction, which is usually the case, a high sampling rate is needed to keep up with this algorithm. This is a common issue when averaging several readings.
  1. Simple RF remote control code
    Last Post: - 22nd January 2014, 11:45
  2. Simple Blinking LED - WTF!!
    By johnnylynx in forum mel PIC BASIC Pro
    Last Post: - 1st February 2010, 07:19
  3. Simple LCD code not working!...WHY?
    Last Post: - 29th November 2009, 20:48
  4. what's wrong 16F877A simple code?
    Last Post: - 30th October 2009, 02:11
  5. Doing Simple Math - getting the wrong answer
    Last Post: - 8th March 2005, 15:27
