water flow meter..
Results 1 to 10 of 10
    ecca's Avatar
    ecca Guest
    Default water flow meter..
    Hi everyone,
    I'm looking for ideas.
    I want to use a flow sensor to measure incoming water flow using a PIC chip.
    I have Pic basic pro.
    The sensor I have, and it delivers 3000 odd pulses per litre.
    I want to display on a LCD display the amount of water flowed, in litres.
    I want the data to be retained when the power is switched off and I want a reset switch to zero it.
    I'm not bothered about the hardware aspects of it but would appreciate help with the program writing.
    Anyone help me ?
    Cheers
    Ecca
    Sep 2005
    Campbell, CA
    For starters -
    Upon power up, read the LITRES counter out of two bytes of EEPROM (a WORD variable), write that value to LCD. Then sit in a loop and count the number of pulses and watch the switch. When 3000 pulses have been counted, clear that counter and increment the LITRES counter. Write that value back to EEPROM and update the LCD.
    When you detect that a button has been pushed, clear the LITRES counter, updated the LCD and write the ("0") value back to EEPROM.
    Charles Linquist
    Hangover, Germany
    Don't write to often to the EEPROM on the same position !
    Think about a ring-buffer !
    Maybe:
    Get the olf value.
    Count...
    Write the new value to the next position and a checksum out of the new and the old value (asume a fixed value for non-existing old values!). If you reach the end of EEPROM, begin on the first position.
    After Power-On
    0: store 0 as backup-value.
    1: read a value, check checksum.
    2: if checksum is ok, store the value as Backup, goto 1
    3: if checksum is bad, use the backup-value and exit
    Just read to manual !
    Maybe you can build hardware to buffer the pic fpr around 10ms to write the eeprom and then turn off. Use the Brown-Out-Reset !!!!
    Mentor, Ohio
    Hi Ecca,
    Can you provide us with some information on the flow meter, such as the manufacturer and part number, perhaps a web site to look at this sensor closer?
    BobK
    For saving to the EEPROM, choose a PIC with a LVD (Low Voltage Detect) interrupt.
    When the power is turned off, the interrupt gets triggered, quickly save to EEPROM while the chip is still running on the capacitor charge.
    The rest of the time, the value is available in RAM. No need to save it on every loop.
    Or a comparator interrupt OR modify the power supply. You place a diode between the bridge and the capacitor, then send the bridge side on a interruptable pin.
    Just another idea
    How many different ways exist to skin a cat?
    Sep 2005
    Campbell, CA
    The 18F8722 datasheet claims the EEPROM is typically good for a million write cycles. I would probably trust it for 500K cycles.
    Charles Linquist
    ecca's Avatar
    ecca Guest
    Right then, having returned from holidays..... I continue.
    I only require a 3 digit LCD with about 12mm digits.
    What's around at the moment ?
    Thanks for help all,
    Ecca
    Mar 2009
    Colorado
    Smile Please forward info for your flow sensor!
    Quote Originally Posted by ecca View Post
    Hi everyone,
    ecca, in hopes you will still receive this notice on this old thread, I have a similar reqirement and would greatly appreciate any info you have on your flow sensor....better yet even a data sheet. Please forward info to me at [email protected].
    In similar cases I use magnetic flow sensors from Krohne. They do not have any moving parts and only require metal pipes or metal rings to work.
  1. Hall Effect flow meter with 16F876
    By revelator in forum mel PIC BASIC Pro
    Last Post: - 10th March 2010, 20:42
  2. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 02:35
  3. NMEA 2000 Flow Meter
    By Joe Rocci in forum mel PIC BASIC Pro
    Last Post: - 6th August 2008, 00:35
  4. Electric water valve
    By Christopher4187 in forum Off Topic
    Last Post: - 6th April 2008, 21:41
  5. hot water flow sensor
    By jessey in forum Off Topic
    Last Post: - 24th January 2007, 04:05
