V 2.60 and DT Instant Interrupts?
Results 1 to 10 of 10
    Default V 2.60 and DT Instant Interrupts?
    I was wondering if Mr. Taylor's great Instant Interrupts will work with the new PBP upgrade, specifically the 18F87J90 family?
    Who says there is a version 2.60?
    http://microsound.co.za/cart/product...roducts_id=446
    http://www.scalerobotics.com
    Sep 2005
    Campbell, CA
    I ordered my copy today from MCUmart.
    Charles Linquist
    Feb 2003
    Sydney, Australia
    I had a look on melabs and MCUmart, but can see no mention of 2.60. Any more info anyone ?
    Bill.
    Yes, DT_INTS works with 2.60.
    I have not updated DT_INTs-14 to work with the new Enhanced Core PIC's since I can't seem to get any of those chips.
    They may even need their own DT_INTS-14E files. Not sure yet.
    Once I get some chips, I'll do it. Can't wait to try them out.
    P.S. Some vendors still have 2.50 as the PBP upgrade.
    Make sure they are offering 2.60 when ordering.
    I know Rentron.com has the new one. Got mine there.
    And what news does the 2.60 bring?
    Sep 2007
    As always, many new parts. New libraries have been created for
    the 14-bit enhanced core.
    The MPLAB integration has been reworked in response to Microchip
    dropping COD file support. COFF files are now generated for all
    cores, without requiring use of MPLINK. A batch-execution method
    has been added to alleviate the requirement of PATH variable
    modifications. A build-options checkbox for PBPL has been added.
    New commands/operators are:
    ARRAYREAD
    ARRAYWRITE
    'These commands allow you to treat an array variable with the
    'ASCII format modifiers like DEC, HEX, BIN, etc.  You can write
    'strings into an array (format), or read values from a string in
    'an array (parse).   Examples:
    	string1	VAR BYTE[24]
    	string2 VAR BYTE[24]
    	ARRAYWRITE string1, [REP 0\24]  ' fill string with zeros
    	ARRAYWRITE string1, ["ADC Value: ", DEC value] ' store display string
    	ARRAYREAD string1, 24, not_found, [WAIT(":"), DEC value] ' parse a value
    	ARRAYWRITE string2, [STR string1\24]  ' copy from one array to another
    DO    'new syntax for loops, tests are WHILE/UNTIL, at DO or LOOP
    LOOP
    ELSEIF     'allows multiple sections of IF..THEN with conditionals
    EXIT       'jump to end of DO, FOR, REPEAT, etc.
    ON GOTO    'alternate syntax for BRANCHL
    ON GOSUB   'BRANCHL, but calls with GOSUB and allows RETURN
    ATN        'arctangent
    HYP        'hypotenuse
    Charles Leo
    microEngineering Labs, Inc.
    http://melabs.com
  1. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 20:02
  2. DT Instant Interrupts help
    By perides in forum mel PIC BASIC Pro
    Last Post: - 26th November 2008, 18:41
  3. 12F683 and DT Instant Interrupts
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 12:47
  4. 18F1220 and DT Instant Interrupts
    Last Post: - 30th June 2008, 05:37
  5. Replies: 1
    Last Post: - 1st November 2006, 03:11
