Command Line Compile
Results 1 to 19 of 19
    Default Command Line Compile
    I am near beta stage with a new standalone FineLine IDE for both Proton and MEL PicBasic!
    I would like to utilize the command line compile but am stuck.
    The following is what I am trying (as per manual) in Windows run but doesn't work:
    E:\1PicBasicPro\PBP\PBPL.exe -ampasmwin -p18f4520 E:\1PBP\Headings\09-06-26-05 18F4520 4MHz Heading,Int OK.bas
    I am looking for a hex file in the above E directory with a new time modified.
    Norm
    Here is the guts of a *.bat file I use.
    cd
    cd C:\MAC_PROGS\PPPBP\
    PBPL -e -ampasmwin -p18F4550 test.bas
    cd\
    The above works if the "paths" are set in windows environment.
    Maybe it will give you a clue. Your part about "time modified" has me a bit confused.
    When there are spaces in the filename, you need to put quotes around it.
    E:\1PicBasicPro\PBP\PBPL.exe -ampasmwin -p18f4520 "E:\1PBP\Headings\09-06-26-05 18F4520 4MHz Heading,Int OK.bas"
    I meant date modified.
    Does the newer PBPL save a .pbp in place of a .bas file for compile?
    In windows run
    E:\1PicBasicPro\PBP\PBPL.exe -ampasmwin -p18f4520 "E:\1PBP\Headings\09-06-26-05 18F4520 4MHz Heading,Int OK.pbp"
    gets a brief flash of a DOS screen but no updated .hex file.
    Norm
    pbp or bas. both are valid.
    Check the error file to maybe see what is wrong. Could be an error in the code. If so then a hex will not be created or updated.
    Do you have C:\Program Files\Microchip\MPASM Suite; in your PATH?
    This is what I use when on a Linux box and do not have the "paths" set.
    cd /home/shop/MAC/PIC\ LINUX/SweepBot
    wine c:/pbp/pbpw -e -s -ac:/Program\ Files/Microchip/MPASM\ Suite/MPASMWIN -p16f676 z:/home/shop/MAC/PIC\ LINUX/SweepBot/SB1.bas
    wine c:/Program\ Files/Microchip/MPASM\ Suite/mpasmwin /e /l SB1.asm
    Basically what happen is PIC BASIC does it's thing by making an ASM file per MPASM's standards, and then MPASM runs to convert the ASM to HEX.
    Should work on windows too...Once you get rid of the "wine" and fix up the "/ \ / \ / \"
    Path set as:
    I:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\;I:\P rogram Files\Borland\BDS\4.0\Bin;%SystemRoot%\system32;%S ystemRoot%;%SystemRoot%\System32\Wbem;I:\Program Files\Microchip\MPASM Suite
    Windows run doesn't take a "cd" no quotes.
    Also trying in a Delphi program ShellExecute(Handle, 'open', PChar(Edit1.TEXT), nil, nil, SW_SHOWNORMAL);
    My conversion, not working from windows run(brief DOS flash) or Delphi shell(nothing):
    e:\1PicBasicPro\PBP\PBPL -e -s -ai:\Program Files\Microchip\MPASM Suite\MPASMWIN -p18f4520 e:\1PBP\Headings\test.pbp
    e:\1PicBasicPro\PBP\PBPL -e -s -ampasmwin -p18f4520 e:\1PBP\Headings\test.pbp
    Norm
  1. Unable to pass a variable to LCDOUT without getting compile errors
    By Ferroto Baggins in forum mel PIC BASIC Pro
    Last Post: - 28th February 2010, 16:43
  2. Compile and Program help using PICKit2
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 10th March 2009, 14:51
  3. USB PBPL Compile errors
    By Rob in forum USB
    Last Post: - 7th April 2008, 08:18
  4. Cannot compile for 40MHz 4 x pll
    By passion1 in forum mel PIC BASIC Pro
    Last Post: - 21st October 2007, 17:50
  5. Replies: 2
    Last Post: - 9th February 2006, 22:03
