HSEROUT and Commas, What? Help Me Understand
Results 1 to 5 of 5
    Apr 2009
    Unhappy HSEROUT and Commas, What? Help Me Understand
    Hello,
    Okay so I am having a weird problem, that really isn't a problem as I can work around it. I just think that it shouldn't be working this way as I have seen no code online written that way.
    Here is what I am doing, I have a remote control system that transmits the status of nine momentary switches to a receiver that then turns on the corresponding reed relay.
    I had the hardest of time getting the serial to "work", I wrote a simple program to turn on a led once com was set to "1" and state to "O", which is received over the hardware port, with AX as the qualifier.
    I played with it for a while and no matter what I did I couldn't get the led to turn on. I had a usb to serial cable laying around but I didn't have a converter, so I ended up just ripping the box open and soldering on to the usb to serial chip before the TTL serial to RS-232 Serial converter. After doing that I opened up microcode studio serial terminal and checked the transmitting string, I would receive this AX1O, "AX" qualifier, "1" port one, "O" on. So the transmitter was working, but not the receiver.
    I then tried sending AX1O from the terminal but that didn't work either. Finally about six hours over two days later I thought, well lets try sending this, AX,1,O wow it worked . So then I programmed the transmitter to send that like this HSEROUT ["AX",",",DEC 1,",","O"] and sure enough it worked.
    My question is, Why do I have to have the commas?
    Below is the code for the transmitter and receiver, respectfully:
    PS If you know a better way please tell me, thanks.
    'Author: Albert Eardley
    'Writen for 16F628A
    DEFINE OSC 20
    CMCON = %00000111
    OPTION_REG = %11000000
    HIGH PORTA.2
    HIGH PORTA.3
    PAUSE 300
    DEFINE HSER_SPBRG 255 ' 1200 Baud @ 1.75%
    mytimer VAR BYTE
    mytimer = 0
    power VAR PORTA.2
    switch0 VAR PORTB.0
    switch1 VAR PORTA.1
    switch2 VAR PORTA.5
    switch3 VAR PORTB.3
    switch4 VAR PORTB.4
    switch5 VAR PORTB.5
    switch6 VAR PORTB.6
    switch7 VAR PORTB.7
    switch8 VAR PORTA.0
    INPUT switch0
    INPUT switch1
    INPUT switch2
    INPUT switch3
    INPUT switch4
    INPUT switch5
    INPUT switch6
    INPUT switch7
    INPUT switch8
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
    'INCLUDE "ReEnterPBP.bas"     ' Include if using PBP interrupts
            INT_Handler   TMR1_INT,  _mytimercounter,   PBP,  yes
    T1CON = $31                ; Prescaler = 8, TMR1ON
    MAIN:
    iF switch0 = 0 then
       WHILE switch0 = 0
            mytimer = 0
            HSEROUT ["AX",DEC 1,"O"]
            PAUSE 500
        WEND
        HSEROUT ["AX",DEC 1,"I"]
    IF switch1 = 0 THEN
        WHILE switch1 = 0
            mytimer = 0
            HSEROUT ["AX",DEC 2,"O"]
            PAUSE 500
        WEND
        HSEROUT ["AX",DEC 2,"I"]
    IF switch2 = 0 THEN
        WHILE switch2 = 0
            mytimer = 0
            HSEROUT ["AX",DEC 3,"O"]
            PAUSE 500
        WEND
        HSEROUT ["AX",DEC 3,"I"]
    IF switch3 = 0 THEN
        WHILE switch3 = 0
            mytimer = 0
            HSEROUT ["AX",DEC 4,"O"]
            PAUSE 500
        WEND
        HSEROUT ["AX",DEC 4,"I"]
    IF switch4 = 0 THEN
        WHILE switch4 = 0
            mytimer = 0
            HSEROUT ["AX",DEC 5,"O"]
            PAUSE 500
        WEND
        HSEROUT ["AX",DEC 5,"I"]
    IF switch5 = 0 THEN
        WHILE switch5 = 0
            mytimer = 0
            HSEROUT ["AX",DEC 6,"O"]
            PAUSE 500
        WEND
        HSEROUT ["AX",DEC 6,"I"]
    IF switch6 = 0 THEN
        WHILE switch6 = 0
            mytimer = 0
            HSEROUT ["AX",DEC 7,"O"]
            PAUSE 500
        WEND
        HSEROUT ["AX",DEC 7,"I"]
    IF switch7 = 0 THEN
        WHILE switch7 = 0
            mytimer = 0
            HSEROUT ["AX",DEC 8,"O"]
            PAUSE 500
        WEND
        HSEROUT ["AX",DEC 8,"I"]
    IF switch8 = 0 THEN
        WHILE switch8 = 0
            mytimer = 0
            HSEROUT ["AX",DEC 9,"O"]
            PAUSE 500
        WEND
        HSEROUT ["AX",DEC 9,"I"]
    GOTO MAIN
    mytimercounter:
        mytimer = mytimer + 1
        IF mytimer >= 143 THEN
            LOW power
    @ INT_RETURN
    'Writen for 16F628A
    DEFINE OSC 20
    CMCON = %00000111
    switch0 VAR PORTB.0
    switch1 VAR PORTB.3
    switch2 VAR PORTB.4
    switch3 VAR PORTB.5
    switch4 VAR PORTB.6
    switch5 VAR PORTB.7
    switch6 VAR PORTA.0
    switch7 VAR PORTA.1
    switch8 VAR PORTA.2
    com VAR BYTE
    state VAR BYTE
    MAIN:
    LOW switch0
    LOW switch1
    LOW switch2
    LOW switch3
    LOW switch4
    LOW switch5
    LOW switch6
    LOW switch7
    LOW switch8
    MAIN1:
    HSERIN [WAIT("AX"), DEC com, state]
    SELECT CASE com
        CASE 1
            WHILE state = "O"
                HIGH switch0
                HSERIN 2000,MAIN,[WAIT("AX"), DEC com, state]
                IF com != 1 THEN MAIN
            WEND
            GOTO MAIN
        CASE 2
            WHILE state = "O"
                HIGH switch1
            WEND
            GOTO MAIN
        CASE 3
            WHILE state = "O"
                HIGH switch2
            WEND
            GOTO MAIN
        CASE 4
            WHILE state = "O"
                HIGH switch3
            WEND
            GOTO MAIN
        CASE 5
            WHILE state = "O"
                HIGH switch4
            WEND
            GOTO MAIN
        CASE 6
            WHILE state = "O"
                HIGH switch5
            WEND
            GOTO MAIN
        CASE 7
            WHILE state = "O"
                HIGH switch6
            WEND
            GOTO MAIN
        CASE 8
            WHILE state = "O"
                HIGH switch7
            WEND
            GOTO MAIN
        CASE 9
            WHILE state = "O"
                HIGH switch8
            WEND
            GOTO MAIN
        CASE ELSE
            GOTO MAIN
    END SELECT
    Bombay, India
    The reason why - AX1O could as well be a name of a variable. The compiler is not human, and you need to tell it that you mean to send a string which contains AX1O.
    You could send HSEROUT["AX1O"]. Much cleaner this way.
    If you send as you do, the commas are needed because, each value in quotes is treated as a sequence of bytes (string). So, HSEROUT knows what to do with each.
    Apr 2009
    Not sure I understand, everybody's code I've seen always has something like this,
    HSEROUT [B0, DEC 6] or how ever else you want to write it and the receiver is like this
    HSERIN [B0var, DEC number]
    I even saw one guy's command that looked like this:
    HSEROUT [$FE,$47,0,2,"RPM = ", DEC5 RPM] (is sending to a serial lcd most likely but still)
    and thus I was wondering why, in my case, does HSERIN need the commas to be transmitted (sorry if you've explained it, I just don't understand as I thought it was on the HSERIN side not the HSEROUT side)?
    Bombay, India
    You only need to transmit the commas if you expect HSERIN to read the commas. It is like sending a '0' character and expecting HSERIN to see a '0'. Think of it as a place holder or separator or as in C, a parameter separator. If you use it in that context, yes, you will need the comma to be transmitted as well as read.
    Examples you quoted of HSEROUT [B0. Dec num] send out the value of variable B0 followed by the Decimal representation of num. Let us take B0 to be holding a value 123 and the value in num to be just 5. What HSEROUT sends down the line is
    1235
    Now, when HSERIN is trying to decipher this stream it would not know how much of the number 1235 belongs to B0. So, put a 'non-number' between the 2 numbers and HSERIN will now smart up and know which numbers go where.
    let us see
    HSEROUT [B0, "," , Dec Num] will now send this
    123,5
    When HSERIN [B0var, CommaVar, NumVar] tries to read this, it will capture the number preceding the comma into B0var and the Comma into CommaVar and Num into Numvar. That is the reason for the commas in the odd places you see.
    Hope it is clear this time
    cheers
    Apr 2009
    thanks that makes sense.
