12f675 very confused
Results 1 to 6 of 6
    Jan 2007
    Default 12f675 very confused
    I have made the program below to run a simple leak test fixture. The problem I am having is that the machine randomly gets lost and the two bottom seal variables lock in the 0 or off position and do not function unless the power is taken away and the chip is reset. I have tried several different versions of the program to try and fix the problem and by everything i know and have read this should neevr happen in this situatyion. Any help would be much appreciated.
    \\code\\
    CMCON = %00000111 ' set all pins to digital
    GPIO = %00000000 ' set all pin states to off
    TRISIO = %00001000 ' All pin states to out except MCLR for trigger
    WPU = %00000000 ' Shut off weak pull ups
    INTCON = %00000000
    'Register Initializations'
    'Variables'
    SWING_EXT VAR GPIO.0 ' Set variable names for pins
    SWING_RET VAR GPIO.1
    BOT_SEAL_RET VAR GPIO.4
    BOT_SEAL_EXT VAR GPIO.5
    MAIN_TRIGGER VAR GPIO.3
    a0 VAR BYTE ' Byte variables for button
    I VAR WORD ' Word variable for looping
    'Variables'
    INITIALIZE:
    A0 = %00000000 ' INITIALIZE BUTTON BYTE TO ZERO
    BOT_SEAL_RET = 1
    PAUSE 500
    BOT_sEAL_RET = 0
    PAUSE 500
    MAIN:
    SWING_EXT = 1
    PAUSE 500
    GOTO MAIN_TRIG_CHECK
    GOTO MAIN
    MAIN_TRIG_CHECK:
    BUTTON MAIN_TRIGGER, 1, 255, 0, A0, 1, START_OP
    START_OP:
    SWING_EXT = 0
    PAUSE 500
    SWING_RET = 1
    PAUSE 500
    GOTO TEST
    TEST:
    BOT_SEAL_EXT = 1
    PAUSE 500
    GOTO TEST_TRIG_CHECK
    GOTO TEST
    TEST_TRIG_CHECK:
    BUTTON MAIN_TRIGGER, 1, 255, 0, A0, 1, START_OVER
    START_OVER:
    BOT_SEAL_EXT = 0
    BOT_SEAL_RET = 0
    SWING_RET = 0
    swing_ext = 0
    GOTO INITIALIZE
    \\code\\
    Are you using this now on the actual machine, or just with LEDs? I am thinking reverse transients from relays or DUT, (device under test). All inductive devices must use snubber diodes and do not forget to use bypass caps on the PIC, which should be isolated from DUT.
    How are your Config statments set?
    You have analog stuff still turned on, ANSEL and ADCON0 need to be set.
    ANSEL = 0
    ADCON0 = 0
    PCON = %00000011 ' BOD off, No POR flag set
    Jan 2007
    I am using this code on the machine itself right now. The load for all the outputs of the PIC are N-channel mosfets that turn on 12 solenoid valve coils. I have flyback diodes on all the coils to protect the PIC from voltage spikes form the coils. I turnned off the analog registers as you suggested but the problem still exists.
    It seems to be more of an issue when i press the main trigger to quickly comming into the initaialize part of the program. Dont know if thats the cause or just a coincidence. Thank you for your timely help.
    Do you have resistors from the MOSFET gates to the Zero rail?
    Wink
    What I see is you have forgotten to reset the A0 Button var. just before EACH Button Command ...
    Generally it's a fatal error in such loops ...
    Hi Alain, I never use the button command, I wondered about that, I bet that is it too . . .
  1. 12F683 vs 12F675.
    By sccoupe in forum mel PIC BASIC Pro
    Last Post: - 11th July 2009, 05:58
  2. LANC code 12F675
    By MikeDD in forum General
    Last Post: - 9th May 2008, 06:44
  3. Instant Interupts with a 12f675
    By wlundonly in forum mel PIC BASIC Pro
    Last Post: - 26th January 2008, 02:52
  4. 12F675 won't reprogram or erase
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 19th May 2006, 06:07
  5. 12f675 serial pic2pic
    By tagan in forum mel PIC BASIC Pro
    Last Post: - 12th March 2006, 23:55
