'POT' issues with long cable
Results 1 to 40 of 41
    May 2008
    Italy
    Detecting water level with optical system has one big enemy : The algas growth!
    Al.
    Use Ultraviolet light
    Quote Originally Posted by aratti View Post
    Al.
    Hi Al,
    I was pretty sure You would mention that one, and prepared for it
    Illuminate the tube only while checking level. A 2000 liter tank level is not likely to change very much in an hour, so check intervals do not need to occur too often, still EVENTUALLY algae is likely to occur. Perhaps make the sensor rods screw in for cleaning. Dave's UV light would work, but is expensive.
    A little shot of chlorine down the tube once and a while....
    May 2008
    Italy
    Hi Joe and Dave, going this way it could happen that this thread will come up with the best water level sensor ever invented.
    Al.
    Al.
    Yep, kind of makes your signature line hold true.
    I was googlin around earlier for fiber optics and saw a site advertising "side glow" fiber. It appeared to light up like a neon tube.
    My thought. It it would receive light into the edge ? If so then maybe the more of less exposed would change the intinsity of light at the end? Make it work backwards.
    Anyone played with this stuff?
    http://www.fiberopticproducts.com/Sideglow.htm
    they talk about a very bright like to make it glow, so maybe it would not work...
    I have not played with optics much. What would happen it a glass rod had a flat side?
  1. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 17:45
  2. A/D, Pot, Input, A,B So lost now....
    By Helmutt in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 23:23
  3. Measure cable length with a PIC?
    Last Post: - 15th July 2007, 19:45
  4. Replies: 4
    Last Post: - 24th January 2007, 23:20
  5. pot controlled pwm -- help
    Last Post: - 29th January 2006, 13:29
