Detecting water level with optical system has one big enemy : The algas growth!
Al.
Use Ultraviolet light![]()
Hi Al,
I was pretty sure You would mention that one, and prepared for it
Illuminate the tube only while checking level. A 2000 liter tank level is not likely to change very much in an hour, so check intervals do not need to occur too often, still EVENTUALLY algae is likely to occur. Perhaps make the sensor rods screw in for cleaning. Dave's UV light would work, but is expensive.
A little shot of chlorine down the tube once and a while....
Hi Joe and Dave, going this way it could happen that this thread will come up with the best water level sensor ever invented.
Al.
Yep, kind of makes your signature line hold true.
I was googlin around earlier for fiber optics and saw a site advertising "side glow" fiber. It appeared to light up like a neon tube.
My thought. It it would receive light into the edge ? If so then maybe the more of less exposed would change the intinsity of light at the end? Make it work backwards.
Anyone played with this stuff?
http://www.fiberopticproducts.com/Sideglow.htm
they talk about a very bright like to make it glow, so maybe it would not work...
I have not played with optics much. What would happen it a glass rod had a flat side?
