'POT' issues with long cable
Results 1 to 40 of 41
    How about an ultrasonic transducer like the parallax Ping.
    Put a vertical PVC pipe in the tank, open at both ends, with a float in the middle.
    At the top is the Ping measuring the distance down the pipe to the float.
    Then you have a continuous level sensor.
    California, USA
    The Ping is cute. And its 3 meter range would be just enough for my tallest tank.
    The $30 each price tag is a little tough to swallow since I'd need 3 of them.
    But it would only require a pipe up the side of the tank with a ping pong ball floating in it.
    Hmmm....
    steve
    With the pipe acting as a "wave guide", the range is much further than it would be in open air.
    I think even the previous ideas of submerged capcitors etc. would cost at least $30 in man-hours alone building it.
    You can mount a pipe in a few minutes.
    And you could always "roll your own" with an ultrasonic sensor @ $5.00, if the $30 is too much, but then there's that time vs. money problem again ...
    http://www.sparkfun.com/commerce/pro...oducts_id=8505
    Sounds good, Darrel.
    However, I wonder about 2 things; (a) how would the ambient humidity in a tank (or even that inside the pipe column) affect the transducer's life, and (b) how would the sound of water splashing about, especially when the tank fills up affect the readings?
    Would it not be far more acurite to use a cheep pic at the tank with 'digital' probes and then comm lines back to main pic?
    Other than that, i'm wondering why your using cap/resister solution...
    Would two rods running all the way down the tank, one charged with say 5V DC and the other connected to a analogue port... as the water rises the resistance between the two rods changes and therefor the voltage on the analogue port would rise...
    Just a thaught...
    Aug 2005
    Why not use a pressure switch like the kind you find in a washing machine, you can use the switch to turn the pumps on and once the required pressure is reached the pumps will cut off.
    Sphere.
    Hmmm, yup pressure works good too.
    12 Ft/head = ~5 PSI if I remember right?
    Maybe an MPX???? (tube version) with some scalerobotics code.
    Feet of head, instead of altitude. ??
    Altimeter : up to 16 bit altimeter solution
    http://sites.picbasic.net/component/...,91/pageid,81/
    MPX4115A Datasheet (up to 16 PSI)
  1. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 16:45
  2. A/D, Pot, Input, A,B So lost now....
    By Helmutt in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 22:23
  3. Measure cable length with a PIC?
    Last Post: - 15th July 2007, 18:45
  4. Replies: 4
    Last Post: - 24th January 2007, 22:20
  5. pot controlled pwm -- help
    Last Post: - 29th January 2006, 12:29
