'POT' issues with long cable
Results 1 to 40 of 41
Threaded View
  1. #30
    May 2008
    Italy
    I wonder how well they would like water inside them
    Generally air pressure sensor hate water. But in this case the sensor can be located far away from water tank. All you need is a tube (the larger it is the best resolution you get) with the top end sealled and connected via a small plastic tube to your sensor. The open side of the tube is deeped into water so that if the level increase the space, inside the immersed tube will decrease and as a conseguence the air pressure will increase. The only problem with this method is that Pressure = volume * temperature (gas equation). So if temperature double also the pressure inside the tube will double without any change in water level. This to warn you to use also a temperature sensor and compensate the pressure reading for the temperature change.
    Al.
  1. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 16:45
  2. A/D, Pot, Input, A,B So lost now....
    By Helmutt in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 22:23
  3. Measure cable length with a PIC?
    Last Post: - 15th July 2007, 18:45
  4. Replies: 4
    Last Post: - 24th January 2007, 22:20
  5. pot controlled pwm -- help
    Last Post: - 29th January 2006, 12:29
