Brownout detected 16F877
Results 1 to 6 of 6
    Jan 2008
    Pennsylvania
    Default Brownout detected 16F877
    Hi all... I'm not sure what is causing the brownout on my pic but it is most likely a design flaw of my circuit. I'll start by: The brownout is tripped when the pic senses a voltage drop that could affect it correct? I am using 2 pins on the pic to trip these 2 reed relays, I have the relays going to +5vdc on one side and to the porta.2 and porta.5. I do not have any pull up resistors or anything else wired into the relays. When I want to trip the relays I set the appropriate port to 0, porta.2=0 when I am ready to shut the relay off I set porta.2=1 every once in a while when I shut the relays off the device just reboots. I am guessing this is the brownout event taking place. I realize I am not laying out my entire circuit here but I thought I would start with this just to see if anyone has any suggestions on what I might check or look for to try and troubleshoot this. If anyone has any ideas on what to check or suggestions I would appreciate it.
    David
    Flyback diode on the relays may help.
    Jan 2008
    Pennsylvania
    Default flyback diode
    Mack, Thanks I will give that a try. That would just be a simple Schottky diode across the load of the realy right?
    David
    Any type is better than none.
    http://en.wikipedia.org/wiki/Flyback_diode
    Jan 2008
    Pennsylvania
    Default As always thanks
    [QUOTE=mackrackit;76156]Any type is better than none.
    http://en.wikipedia.org/wiki/Flyback_diode[/QUOTE
    So far so good... It has not rebooted itself since I added the flyback diodes to the circuit.
    I'm very appreciative of the people in this forum you're always a great help.
    David
    Cool! That makes my day
  1. 16f877 and ps/2 keyboard error???
    By boraciner in forum mel PIC BASIC Pro
    Last Post: - 5th July 2009, 08:14
  2. serial communication between CMUcam and PIC 16F877
    By gengkeys in forum mel PIC BASIC Pro
    Last Post: - 30th March 2007, 06:43
  3. 4 Quadrant dc drive with 16F877
    By mns45 in forum mel PIC BASIC
    Last Post: - 23rd February 2006, 13:05
  4. problem using 16f877
    By yrch in forum mel PIC BASIC Pro
    Last Post: - 20th February 2006, 18:58
  5. Compatibility in between 16f877 and 18f452
    By BIDOUILLE in forum mel PIC BASIC Pro
    Last Post: - 11th October 2005, 13:59
