Always helps to go back to the definition of the problem:
Questions:
Does <b>"sometimes"</b> mean some units all the time or any unit some of the time? Do the bad units fail every time or not every time?
Does <b>"all the IO's"</b> really mean all? GP0 to GP4 are normally at 5V at turn on as they have their pull-up resistors to 5V. How close to 5V are they? Same voltage to a millivolt or so or are they measurably lower or higher? (If different that tells us where current is going, the amount of difference tells us how much current).
And when failing, are Vdd and Vss still normal?
