Serout to serial servo
Results 1 to 21 of 21
    Feb 2007
    Malaysia
    Hi Mr aratti,
    I've tried the code but still didn't work.
    I can do it easily with BS2 but it seem difficult with Pic. It's almost the same between Pbasic(BS2) and Picbasic Pro(Pic) but yet its not working.
    May 2008
    Italy
    Tray adding a pace delay (see pag 140 PBP manual) number represent milliseconds delay between characters.
    example:
    SEROUT2 Lleg,396,1,[255,5,125,101,181,154,126,182]' B6 'repeated 7X,
    This will delay 1 millisecond, perhaps you will need it longer.
    Al.
    Feb 2007
    Malaysia
    Still can't get it to work.
    Any other suggestion?
    I really need help from forum members.
    I have to ask. Can you make an LED blink with the correct timing?
    What do you get if you connect the PIC to a terminal? Is it sending anything?
    Feb 2007
    Malaysia
    I just found out that I can't even make an Led to blink. Maybe there's a problem with the Pic itself. I will try to use another Pic this evening and try again with the code provide by arati.
    Quote Originally Posted by azmax100 View Post
    Hi azmax100,
    Let's pretend we never used a BS2, and we are using just PICs, and lose Include BS2Defs . . . and all their hokey renaming of ports cause it really just confuses hell out of me anyway.
    Go back to the basics, check your config settings, did you set tris and port registers properly, disable all the analog . . . does your chip have ansel, adcon, adcon1, adcon0, cmcon, cmcon0, cmcon1, . . . . Did you DEFINE OSC ? Does it match the config ? Is mclr or mclre enabled? If so do you have a pullup resistor ? Make sure the LED is not reverse biased (this is an issue, I have LEDs where the Anode is the long lead and I have LEDs where the cathode is the long lead). Is the power supply voltage correct and of sufficient power output? Is it filtered properly? Make sure LVP is disabled, until all is working, enable PWRTE and WDT
    I was afraid of that. So, like Joe said, lets start from scratch.
    First, these are a must read:
    http://www.picbasic.co.uk/forum/showthread.php?t=562
    Now for the configs. In the PBP directory you will see *.inc files as the thread above talks about. Comment out the correct lines. Make it look like this.
        NOLIST
        ifdef PM_USED
            LIST
            include 'M16F87xA.INC'  ; PM header
         ;   device  pic16F877A, xt_osc, wdt_on, lvp_off, protect_off
            XALL
            NOLIST
            LIST
            LIST p = 16F877A, r = dec, w = -302
            INCLUDE "P16F877A.INC"  ; MPASM  Header
       ;     __config _XT_OSC & _WDT_ON & _LVP_OFF & _CP_OFF
            NOLIST
            LIST
    I will assume you are using Micro Code Studio. Make sure MPLAB is installed and have MCS set to use MPASM. This is not really needed for this PIC but in the future it will be so we will start off right. In MCS tool bar - View-Compiler and Program Options- then the Assembler tab. Check use MPASM.
    Now for some basic code to see if all is working.
    '16F877A       HEART_BEAT
        DEFINE OSC 20
        @ __config _HS_OSC & _WDT_OFF & _LVP_OFF & _CP_OFF &_BODEN_OFF
        ADCON1=7
        CMCON=7
    START:
        HIGH PORTD.2
        PAUSE 100
        LOW PORTD.2
        PAUSE 100
        GOTO START
    When the above is working we can do a simple serial output to a terminal. MCS has on built in.
    Feb 2007
    Malaysia
    I am very sorry to trouble you people with my problem. I really appreciate your help.
    Now I can make the leg moving but after three or four move it will stall. It's seem like I have to off and on the signal voltage to make it move smoothly. I don't know what happen.
    This is my first time with serial servo and humanoid.
    here is my code:
    [/CODE]
    include "BS2DEFS.bas"
    @ DEVICE HS_OSC ' System Clock options
    @ DEVICE LVP_OFF ' Low-Voltage Programming
    DEFINE OSC 20
    ADCON1 = 7 ' all digitals
    CMCON = 7 ' all digitals
    TrisB = %00000000 'Setup port b as all outputs
    Trisd = %00000000
    PortB = %00000000
    PortD = %00000000
    Rleg var portb.2
    Lleg Var portd.1
    PAUSE 1000
    GOSUB Stand
    GOSUB PostR
    gosub R1a
    gosub R2a
    gosub R3a
    gosub R4a
    gosub R5a
    gosub R6a
    R1a:
    SEROUT2 Rleg,396,20,[255,5,130,145,94,111,110,85]
    SEROUT2 Lleg,396,20,[255,5,90,110,161,144,145,145]
    PAUSE 500
    R2a:
    SEROUT2 Lleg,396,20,[255,5,40,110,161,144,145,95]
    PAUSE 500
    R3a:
    SEROUT2 Rleg,396,20,[255,5,150,145,94,111,120,115]
    SEROUT2 Lleg,396,20,[255,5,40,150,161,144,145,135]
    PAUSE 500
    R4a:
    SEROUT2 Lleg,396,20,[255,5,40,60,131,144,145,15]
    PAUSE 500
    R5a:
    SEROUT2 Lleg,396,20,[255,5,50,110,161,144,145,105]
    PAUSE 1000
    R6a:
    SEROUT2 Lleg,396,20,[255,5,50,110,161,94,145,55]
    PAUSE 1000
    R7a:
    PAUSE 1000
    R8a:
    SEROUT2 Lleg,396,20,[255,5,50,110,161,144,105,65]
    PAUSE 1000
    R9a:
    PAUSE 1000
    R10a:
    SEROUT2 Lleg,396,20,[255,5,140,110,161,144,120,170]
    PAUSE 1000
    Stand:
    SEROUT2 Lleg,396,20,[255,5,125,110,161,144,120,155]
    SEROUT2 Rleg,396,20,[255,5,130,145,94,111,135,110]
    PAUSE 1000
    PostR:
    SEROUT2 Lleg,396,20,[255,5,130,110,161,144,110,150]
    PAUSE 1000
    [CODE]
    Last Post: - 8th March 2010, 21:58
  2. serial ports, the servo control.
    By m.nobre in forum Serial
    Last Post: - 7th December 2009, 17:16
  3. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 09:40
  4. Serial Servo Spider
    By gandora in forum mel PIC BASIC Pro
    Last Post: - 21st May 2007, 07:48
  5. Keypad unlock (as in garage door possibly)
    By Fred in forum Code Examples
    Last Post: - 2nd April 2006, 05:26
