I2C and 24LC65
Results 1 to 7 of 7
Thread: I2C and 24LC65
    Mar 2005
    Madison, WI, USA
    Default I2C and 24LC65
    I have been unsuccessfully working with a MicroChip 24LC65 trying to get the example in the PBP Manual to work with a 16F628A. I have built the circuit exactly as shown in the book with 4.7K pullups on the data and clock lines. The example being that for the I2C command.
    I am using a 4Mhz clock oscillator and the circuit is supplied with 5vdc. I have set the MClr pin as in the diagram and pulled it up also. I have grounded the various EPROM pins as the diagram shows.
    I am using the hardware serial capability of the 16F628A to send program output to "Hyperterm" running on my notebook.
    I have created the example coded as included below. The result returned from each of the three read statements is always "255." I don't think it is merely a coincidence that all the bits are 1's. I am not sure if this is a hardware problem, software problem or combination of both. I have read the 24LC65 data sheet and tried to understand what I can. It seems like there may be some hardware characteristics of this part that are not entirely compatible with the instructions given in the PBP manual, but I can't quite put my finger on that. Please look through the code below and see if you can spot an error. Perhaps I just destroyed the EPROM accidentally.
    The code follows:
    ' EP_Test.bas
    ' 16F628A- CPU Hardware Layout
    ' EPROM Hardware: MicroChip 24LC65
    ' RA0- Eprom data line (SDA), open drain, 4.7K pullup
    ' RA1- Eprom clock line (SCL), open drain, 4.7K pullup
    ' RA2- n.c.
    ' RA3- n.c.
    ' RA4- n.c.
    ' RA5- MasterClear is enabled just to match manual and jumpered high.
    ' RB0- n.c.
    ' RB1- n.c.
    ' RB2- HSER- Out to HyperTerm Display
    ' RB3- n.c.
    ' RB4- n.c.
    ' RB5- n.c.
    ' RB6- n.c.
    ' RB7- n.c.
    @ __config _HS_OSC & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF & _PWRTE_OFF & _BOREN_OFF
    CMCON=7
    Define OSC 4
    Define HSER_BAUD 2400
    Define HSER_RCSTA 90h
    Define HSER_TXSTA 20h
    B0 var byte
    B1 var byte
    ' Set the tri-state registers using bits
    TRISA=%00000000
    TRISB=%00000000
    ' Initialize the ports using bits
    PortA=%00000000
    PortB=%00000000
    Pause 1500
    ' start the eprom stuff
    B0 = 0
    I2CWRITE PortA.0,PortA.1,$A0,B0,[B0]
    Pause 700
    B0 = 1
    Pause 700
    B0 = 2
    Pause 1500
    B0 = 0
    I2CREAD PortA.0,PortA.1,$A0,B0,[B1]
    Hserout [#B1,13,10]
    Pause 700
    B0 = 1
    Hserout [#B1,13,10]
    Pause 700
    B0 = 2
    Hserout [#B1,13,10]
    May 2008
    Italy
    Add the following two DEFINEs to your code
    DEFINE I2C_SLOW 1
    DEFINE I2C_HOLD 1
    Declare and use the following constants as reading and writing control.
    SDevW           con %10100000       ' I2C eeprom write control
    SDevR           con %10100001       ' I2C eeprom read control
    You should have all the address inputs grounded.
    Al.
    Hello afbecker,
    Here is an example which might be helpful:
    ' I2CREAD and I2WRITE Commands with External EEPROM on 12-bit core
    ' Write to the first 36 locations of External I2C EEPROM
    ' Read from eeprom and output sequentaly then as strings
    ' Tested on 12F675  using 24LC01B EEPROM
    @ __config _INTRC_OSC_NOCLKOUT & _PWRTE_ON & _WDT_ON & _MCLRE_ON & _CP_OFF & _BODEN_OFF
    DEFINE DEBUG_REG	GPIO
    DEFINE DEBUG_BIT	2
    DEFINE DEBUGIN_BIT	5
    DEFINE DEBUG_BAUD	2400
    DEFINE DEBUG_MODE	0
    DEFINE SHIFT_PAUSEUS 1000
    EECON1   = 7  'Probably not needed here, enables internal eeprom
    CMCON    = 7  'Disable comparators
    ADCON0.0 = 0  'Disable A/D converters
    ANSEL    = 0  'Disables Analog Select
    DPIN var GPIO.0   'Assign Data pin
    CPIN var GPIO.1   'Assign Clock pin
                ' a nice place to store things
    B0 var byte
    B1 var byte
    B2 var byte
    B3 VAR BYTE
    GPIO   = 0 ' set port latches low
    TRISIO = 0 ' set ports as outputs
    pause 1000 ' Waste time while serial LCD initiailizes
    For B2 = 0 To 35   ' counter for lookup table
    lookup b2,["A","B","C","D","E","F","G","H","I","J","K","L","M",_
    "N","O","P","Q","R","S","T","U","V","W","X","Y","Z","0","1","2",_
    "3","4","5","6","7","8","9"],B0 ' store each char in b0 1 at a time
    I2CWRITE DPIN,CPIN,$A0,B2,[ b0]  'write to 24C01 eeprom 1 character
    Pause 20
    Next B2       'next character write to eeprom
    DEBUG 254,1   'clear LCD of any leftover data
    loop:
    DEBUG 254,1   'clears away the leftovers each loop
    For B3 = 0 To 35   ' counter for reading 35 characters
    I2CREAD DPIN,CPIN,$A0,b3,[B1]  ' read each character 1 at a time
    pause 500           ' time to see each character on the LCD
    DEBUG 254,2,"CHAR ",B1,"          " ' display the characters 1 at a time
    Next B3                             ' get next character
    I2CREAD DPIN,CPIN,$A0,0,[STR B1\20] ' read a string of  20 characters
    DEBUG 254,2,STR B1\20               ' display those 20 characters
    I2CREAD DPIN,CPIN,$A0,16,[STR B1\16]' get the last 16 characters
    DEBUG 254,$C0,STR B1\16,"    "      ' display those 16 characters
    DEBUG 254,$94,"I2C EEPROM DEMO"     ' display this program's purpose
    DEBUG 254,$D4,"USING ARRAY & STRING"
    PAUSE 1500                          ' time to read the LCD
    'NEXT B3                            ' go do it all again
    Goto loop
    POKECODE @$3FF, $4C  'read your PIC before erasing and put the cal. data here
    Mar 2005
    Madison, WI, USA
    Default Thanks for the quick reply
    Gentlemen,
    Thanks for the quick reply, I can work on this tonight!
    Aratti: For my future reference, can you tell me what the difference is between the control bytes, particularily the read control byte ending in 1? I wondered if that was the key to making my specific part work.
    Joe S.: I appreciate the code example. Reading example code is a way I find that I can learn new concepts very easily.
    May 2008
    Italy
    Although in this forum, I have read in several posts that I2CRead set the LSB to 1 automatically, I have never been able to read successfully, from external memory, without setting LSB to 1 myself. Now I do it as a standard in all my codes using I2C commands.
    Al.
    Nov 2007
    South-West of Australia. A small town called Denmark. 'Where the forest meets the sea.'
    Default I2c problem
    I think your problem is with the address for READ and WRITE.
    The 24LC64 EEPROM needs a WORD size address - even if the actual address is 0.
    Change your program to
    DEFINE B0 WORD ; Must not be a BYTE size or CONSTANT
    B0 = 0
    I2CWRITE, DataPin,ClockPin,$A0,B0,[Value]
    and so on....
    Good luck. I stuffed around with EEPROM for ages and eventualy found that all my errors were due to using BYTES when the chips expected a WORD. The spec sheet for the chip will tell you what it expects. The example in the PBP book is for a smaller EEPROM that only needs a BYTE address.
    Regards Bill Legge
    Mar 2005
    Madison, WI, USA
    Default The EPROM problem
    Bill,
    You are absolutely correct.
    It came to me last night in a flash (pun intended.) I was re-reading the docs. and I realized I had defined the address variable as a byte type and the address of this part is a word type.
    After I had changed it everything works superbly!
    As a quick reply to Arratti: I am embarassed that I asked the question about the control word difference. At the time I replied I hadn't looked at the EPROM docs. for about two weeks. I forgot the difference in control words was due to the read/write mode.
    Rhetorical question: Isn't it amazing how elementary a problem suddenly becomes once you have figured out the solution?
