I2C with 18F2685
Results 1 to 14 of 14
    I need to invert the address and the control fields and to multiply the address by 2
    Then you are doing something very strange in either your Hardware connections or in Software!
    If fact, I believe you've not realised how the chip is to be addressed (refer to Datasheet 1.4.1). If you have GROUNDED pins A0,A1 and A2, then you would address the chip as $40, but if for example A1 and A2 are GROUNDED and you tie A0 to VDD, then you would address the chip as $42. Note that Bit 0 must be left alone, because it determines if this is a READ or WRITE operation!!!! YOU don't touch BIT-0, it is set for you elsewhere by the I2C commands (which also determines that your ADDRESS must be a BYTE VARIABLE and NOT a Constant).
    I use MCP23008's in several designs with both 16F's and 18F's. PBP Ver 2.46 thru 2.50 has no problems and no issues and allows me to port software across several PIC families which may not have I2C hardware capability. I commonly mix MCP23008's with EEPROM's and RTC's all on the same bus, and up to five devices on the same bus pins are good with 4K7 Pull-Up's.
    I2CWrite SDA,SCL,I2CAddress,I2CRegister,[I2CData]
    Where I2CAddress, I2CRegister and I2CData are all BYTES and previously (for example)...
    I2CAddress=$42 ' Hardware Address of selected MCP23008 Device
    I2CRegister=9 ' Device Register Address being written to
    There is no Hardware initialisation required on the PIC side (other than defining your SCL and SDA pins), but yes, you DO have to initialise your MCP23008's before you use them!
    Here is a typical initialisation sequence at initial Power-On for TWO MCP's being configured for OUTPUT (with different inital ON states)...
    	For CounterA=0 to 1
    		If CounterA=1 then
    			I2CAddress=GPA
    			I2CAddress=GPB
    		For I2CRegister=0 to 9
    			I2CData=0
    			If I2CRegister=9 then
    				If CounterA=0 then
    					I2CData=%11111111
    					I2CData=%00001100
    			Next I2CRegister
    		Next CounterA
    Refer to the MCP's Datasheet for configuring for your own requirements.
    May 2009
    Saint-Quentin-en-Yvelines, FRANCE
    Hi Melanie,
    In fact this is only a matter of definition of the addresses in a specific context.
    If one consider the MCP23008 "as it", its address is determined by A2, A1, A0 and the higher bits which are predetermined for this specific component. At this level of the design nobody knows in which context (program, compiler, hardware) the component is going to be used and the address has to be written as : 20H + (A2,A1,A0). For example, if (A2,A1,A0) = (0,0,1) then the address is 21H. We can call it a physical address and it is only component dependant.
    Now, if we want to pass this address to a PBP program, we have to shift it once left to leave some room for the R/W bit. Therefore this specific byte field value will be obtained by multiplying the physical component address by two (shift left once) and leaving the R/W to 0. At this level and for the hereabove example the field value is equal to 42H.
    Formally speaking, it is not very logical to pass an already shifted physical address to the program but once this is known and clear, no problem, it works.
    Best regards
    MikeBZH / F8DFN
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  4. I2C slave
    Last Post: - 16th March 2008, 04:46
  5. Please help with i2cslave i2c slave
    By cycle_girl in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 14:55
