blinking LED
Results 1 to 15 of 15
Thread: blinking LED
    Apr 2006
    Alberta Canada
    how about the easiest one out there:
    Start:
    High Porta.1
    High porta.0
    Pause 500
    Low Porta.0
    Pause 500                       '1 second
    High porta.0
    Pause 500
    Low Porta.0
    Pause 500                       '2 seconds
    High porta.0
    Pause 500
    Low Porta.0
    Pause 500                        '3 seconds
    High porta.0
    Pause 500
    Low Porta.0
    Pause 500                       '4 seconds
    High porta.0
    Pause 500
    Low Porta.0
    Pause 500                       '5 seconds
    High porta.0
    Pause 500
    Low Porta.0
    Pause 500                       '6 seconds
    Low Porta.1
    goto start
    it might not be the smallest in code size, but it will work and its really easy to understand!!!
    Jan 2006
    Istanbul
    Here is mine.
    No PAUSE used !
    @ DEVICE PIC16F628A, INTRC_OSC_NOCLKOUT, WDT_OFF, PWRT_OFF, MCLR_OFF,PROTECT_ON,CPD_ON ,BOD_OFF,LVP_OFF
    TRISA=0
    TRISB=0
    CMCON=7               ' PortA=digital I/O
    PAUSE 1
    VRCON=0
    PAUSE 1
    PORTA=0
    PORTB=0
    T1CON=%00110001       ' 0.524ms
    TMR1IF VAR PIR1.0       ' Overflow bit of Timer1.
    Output1 VAR PORTA.1     ' Blink 6secs.
    Output2 VAR PORTA.0     ' Blink 0.5secs.
    PreLoad     VAR WORD
    TimeCount   VAR BYTE
    TimetoBlink VAR BYTE
    PreLoad=3036 ' to get 500ms.
    TMR1L=PreLoad.LowByte
    TMR1H=PreLoad.HighByte
    TimeCount=0
    TimetoBlink=12 '12=6secs.
    PAUSE 50         ' OSC to Settle.
    Start:
       IF TMR1IF THEN Blink
       GOTO Start
    Blink: 'Each int is 0.500 sec.
        TMR1L=PreLoad.LowByte   ' Load the timer with preload value.
        TimeCount=TimeCount + 1 ' Count interrupts.
        Output2=Output2 ^ 1     ' Toggle fast blinking output.
        IF TimeCount=TimetoBlink THEN '6Secs ON, 6secs OFF.
          TimeCount=0
          Output1=Output1 ^ 1
        TMR1IF=0                ' Clear TMR1 int. flag.
        GOTO Start
  1. Simple Blinking LED - WTF!!
    By johnnylynx in forum mel PIC BASIC Pro
    Last Post: - 1st February 2010, 07:19
  2. Blinking an led problem on P16F84
    By aimenbukharie in forum General
    Last Post: - 20th March 2009, 06:00
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 21:19
  4. LCD will not start
  5. simple LED Blinking project
    Last Post: - 11th December 2004, 02:25
