blinking LED
Results 1 to 15 of 15
Thread: blinking LED
    	CounterA var Byte
    	LEDA var PortA.0
    	LEDB var PortA.1
    	Low LEDA
    	Low LEDB
    Start:
    	High LEDB			' PortA.1 goes High
    	For CounterA=1 to 6		' For Six seconds
    		Gosub BlinkyOne		' Whilst Blinky blinks
    		Next CounterA
    	Low LEDB			' PortA.1 then goes LOW
    EndLoop:				' and Blinky continues forever
    	Gosub BlinkyOne
    	Goto EndLoop			' until you get bored and switch off
    	'	Subroutine Blinks LEDA across 1 Second
    BlinkyOne:
    	High LEDA
    	Pause 500
    	Low LEDA
    	Pause 500
    C'mon Guys... lets have another five different ways of doing this... then all the students who are using this forum for answers to their homework assignments can each have a different method and not be accused of copying...
    Bombay, India
    	CounterA var Byte
    	LEDA var PortA.0
    	LEDB var PortA.1
    	Low LEDA
    	Low LEDB
    Start:
    	For CounterA=1 to 6*2		' For Six*2    half seconds
    		Gosub BlinkyHalf		' Whilst Blinky blinks
    	Next CounterA
            pause 10000           ' a 10 second gap and then go blinkety blink
    EndLoop:
    	Gosub BlinkyHalf
    BlinkyHalf:
    	Toggle LEDA
    	Pause 500
    Melanie, I hope you don't mind me using my brain to mod your code. However, as you have it, it is a variation of blinky. More to come ??
    Blinkcounter var byte
    clear
    start:
    High porta.1 'high port
    high porta.0 'on led
    low porta.0 'off led
    let blinkcounter = (blinkcounter + 1)
    if blinkcounter < 6 then start
    low porta.1
    low porta.0
    goto start 'keep it going
    untested . . .
    PortA = %00000000
    TrisA = %00000000
    i var byte
    Start:
    PortA.1 = 1
    while PortA.1 = 1
    For i = 0 to 5
    portA.0 = 1
    PortA.0 = 0
    next i
    portA.1 = 0
    wend
    I know, wrong chip and wrong pins... it is what I have on the bench...
    '18F6680'07/14/09'BLINKY
        DEFINE OSC 20
        @ __CONFIG    _CONFIG1H, _OSC_HS_1H
        @ __CONFIG    _CONFIG2H, _WDT_ON_2H &amp; _WDTPS_128_2H
        @ __CONFIG    _CONFIG4L, _LVP_OFF_4L
        CNT VAR BYTE
        FIRST6:HIGH PORTB.2 'SLOW
        FOR CNT = 1 TO 60:TOGGLE PORTG.4:PAUSE 100
        NEXT CNT:LOW PORTB.2:PAUSE 500:GOTO SECOND6
        SECOND6:HIGH PORTB.2   'FAST BLINK--REALLY FAST
        PWM PORTG.4,5,6000
        LOW PORTB.2:PAUSE 500:GOTO [color=#0000FF][b]FIRST6
    May 2008
    Italy
    PortA = 0
    TrisA = 0
    Seconds var Byte
    LED_1      var PortA.0
    LED_2      var PortA.1
    Loop:
    'Your gosub comand goes here
    Goto Loop
    Blink:
    High Led_1
    Seconds = 0
    While Seconds <>5
    High Led_2
    Low Led_2
    Seconds = Seconds + 1
    wend
    Low Led_1
    Here my contribution.
    Al.
    Jul 2009
    untested . . .
    PortA = %00000000
    TrisA = %00000000
    i var byte
    Start:
    PortA.1 = 1
    while PortA.1 = 1
    For i = 0 to 5
    portA.0 = 1
    PortA.0 = 0
    next i
    portA.1 = 0
    wend
    Hi..
    Thanks for all
    I test your code and its working fine but because I am new with picbasic what dose this meen
    PortA = %00000000
    TrisA = %00000000
    When I remove this tow lines the code not working,
    Best regard
    Bombay, India
    PORTA = %00000000 read this as PORTA gets bits 00000000
    This means, write 0 to each bit position of PORTA. Each 0 represents the bits in PORTA from bit 7 to bit 0. You could also write it as
    PORTA = $00 read this as PortA gets Hex 0
    TRISA = %00000000
    This is the tristate register which tells your PIC to allow the values of PORTA to 'drive' the external world circuits. Same as above for the bit position part. If you set any 1 position to 1, that position will only be able to read (INPUT) from the external circuit.
    Clear now? Don't hesitate to ask. See how many responses you got.
    Sep 2003
    INDIA
    Default A slight modification to Sayzer's code
    I am looking for a way to change the rate of blink (Blinking rate) using Interrupt. I would read a POT using ADC and then change the blink rate, Any idea how I could impliment it in Sayzer's code.
    Thanks.
    p.s. maybe using TMR0
  1. Simple Blinking LED - WTF!!
    By johnnylynx in forum mel PIC BASIC Pro
    Last Post: - 1st February 2010, 06:19
  2. Blinking an led problem on P16F84
    By aimenbukharie in forum General
    Last Post: - 20th March 2009, 05:00
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 20:19
  4. LCD will not start
  5. simple LED Blinking project
    Last Post: - 11th December 2004, 01:25
