Reading incremental encoder interupt
Results 1 to 9 of 9
    Default Reading incremental encoder interupt
    Hi
    I would like to make a small project to read an incremental encoder
    with differencial A/B outputs and send its position on request via RS232
    I need to count the pulses, determinate if it is going CW or CCW
    on a serial request I need to send the number of counted pulses via RS232
    Which way shall I go:
    Use I/O ports for the A & B pulses and use a Hardware UART to handle the incoming request of the encoder (the request command is only 2 bytes)
    Or count the pulses of the encoder with an interupt based routine ?
    Any idea's are welcome
    May 2008
    Italy
    I would use the one HCTL2000 quadrature decoder/counter interface.
    See details on datasheet @ http://www.datasheetcatalog.org/data.../HCTL-2000.pdf
    Al.
    What type of frequency are we talking about here? If it's rather low frequency, like a knob used to navigate a user interface etc then perhaps using the 'Change-on-PortB' interrupt and decode and keep count in software. If we're talking higher frequencies, like for motorcontrol etc then you might want to look at the 18F24x1 series PICs as they have a QEI-module on board. In any case - use the USART for comms.
    Thank you
    maximum frequency will be around 1000 Pulses/sec
    I found some devices who can handle differential A/B quadrature encoders
    and give a Direction out and CLK out LS7184
    http://www.opticalencoders.com/asset...atasheet_1.pdf
    I think this device can make the job easier
    If I use this device and the USART on RB1/RB2 of an 16F628 i think I can
    use a normal I/O pin to count the clk from the LS7184
    Or should it be better to use RB0/INT as an interupt from the CLK signal
    from the LS7184 pulse counter ?
    Jun 2008
    Varese , Italy
    Hi ,
    i wrote a picbasic program to read an optical incremental encoder : it used in my DDS frequency generator ( not finished at the moment ) But the encoder piece of program works very well .
    Please note that I am not a software engineer and so the program is not optimized at all.
    Comments are in italian but it is easy to find out the encoder piece that you need.
    Pls: let me know ...
    Ambrogio
    IW2FVO
    North Italy
    Quote Originally Posted by RFsolution View Post
    Hi
    Oct 2013
    Default Re: Reading incremental encoder interupt
    Hi I have a problem with interrupts code in pbp.I want to count encoder ticks in both directions,I have done the code without interrupt routine and it works fine but it is to slow for greater speeds.So I tryed with INT on port B.0 but it is not working.I am useing PIC 16F877A, compiler 2.5. Here is the code which is not working.Where was I wrong?
    proba.txt
    Jun 2008
    Varese , Italy
    I used the interrupt for my low cost mechanical encoder to control my power supply.
    You can find the whole code in the attachement.
    The interrupt service routin is the following:
    ToggleLED1:
    if EB=0 then INC_DEC=2
    IF EB=1 THEN INC_DEC=1
    @ INT_RETURN
    Thanks to Darrel Taylor work.
    Bye
    Ambrogio
    Iw2fvo
  1. decoding quadrature encoders
    By ice in forum mel PIC BASIC Pro
    Last Post: - 28th February 2017, 10:02
  2. Quadrature encoder and ASM Interrupts. questions..
    By godfodder in forum mel PIC BASIC Pro
    Last Post: - 17th March 2013, 15:45
  3. Instant Int and encoder (Elect. Gearing)
    Last Post: - 29th November 2009, 03:29
  4. encoder HEDL 5540
    By kutsi in forum mel PIC BASIC Pro
    Last Post: - 11th June 2007, 15:00
  5. encoder wowes
    By wallaby in forum mel PIC BASIC Pro
    Last Post: - 6th December 2005, 22:56
