Loud Noise at 20khz
Results 1 to 7 of 7
    Default Loud Noise at 20khz
    Good day
    I want to make a VERY loud noise at about 20khz
    I assume I can use the SOUND command, but what speaker or piezo must I use that will make a very very loud noise?
    May 2008
    Italy
    Very likely you will need a speaker and a TBA820 as amplifier, and you will obtain a loud sound out. For a very very loud, you will need a several watts amplifier
    Al.
    Thank you very much aratti!!
    If you want to put out a lot of db at 20khZ you should look into a piezo tweeter to connect to the amp.
    Tim Barr
    Thank you falingtrea.
    Just a thought.
    Will I be able to run a piezo tweeter directly from a pic using the sound command (without any amplifier)?
    Or will the sound not be very loud?
    Hi koossa,
    IMHO a 555 timer is more appropriate for this project, it's analog output will better drive the amplifier than the PICs choppy output. Price ? About the same, you could use a 556 dual 555 and vary the tone with the second timer, Oh, and have more hair left at day's end too.
    Also a 555 can drive load from 12 volts while PIC from only 5.
  1. Pretty Sure a Noise Problem
    By Tobias in forum General
    Last Post: - 10th December 2009, 00:46
  2. Noise on PORTC.0 with PIC16F73
    By passion1 in forum mel PIC BASIC Pro
    Last Post: - 15th February 2009, 20:47
  3. Need suggestions for noise suppression
    By paul.barsamian in forum General
    Last Post: - 29th March 2008, 14:37
  4. PIC to PIC noise problem
    By skerrin in forum mel PIC BASIC Pro
    Last Post: - 9th September 2005, 04:02
  5. (Off Topic) Noise from battery supply
    By CLARE in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2004, 10:01
