urgent: interrupt problem please help
Results 1 to 5 of 5
    Quote Originally Posted by cwmaddy View Post
    I would appreciate any helpin debugging this code
    Code? Where's the code?
    Jul 2009
    Hello
    here is the code
    This is part of main code , I have separated it for debug purposes
    'Configuration bits for PIC16F876A
    @ __config _HS_OSC & _WRT_OFF & _WDT_OFF & _PWRTE_ON & _BODEN_ON & _LVP_OFF & _CP_ALL
    'Defines
    @ #define DEBUG_MODE 1
    DEFINE OSC 10
    define INTHAND ISR ' Define interrupt service routine
    wsave var byte $20 system ' temp save
    wsave1 var byte $A0 system ' If device has RAM in bank1
    wsave2 var byte $120 system ' If device has RAM in bank2
    wsave3 var byte $1A0 system ' If device has RAM in bank3
    ssave var byte $21 syst ' Used to save the STATUS reg. upon interrupt
    psave var byte $22 system ' Used to save the PCLATH reg. upon interrupt
    fsrsave var byte $23 system ' Used to save the FSR reg. upon interrupt
    '------------Required variables---------------------------------------
    detTone var byte
    valDTMF var bit
    timer0_ofcnt var byte
    tonebuf var byte
    timer0 var byte
    enddigit var byte
    bf var byte[8]
    i2 var byte
    j2 var byte
    endindex2 var byte
    buffLen con 8
    'Enable internal pull-up resistors
    Poke $81,%01111111
    'sets up controller porta to DIGITAL instead of analog VIMP
    ADCON1=7
    T1CON =$34
    'Initialize port pins
    'Make entire register B as input
    'Poke TRISB,%11111111
    TRISB = %11111111
    ' Set up interrupts
    T1CON = %00110000 ' Set timer 1 for 1: prescalar, timer mode, on
    OPTION_REG = %00010111
    PIE1 = %00000011 ' Enable timer 1 interrupts
    INTCON = %11010000 'Enable global interrupts,external interrupt
    'Make serial data pins as normal pins for using serout
    RCSTA = %00000000
    'When received tone pair is registered dv becomes 1
    'portB.1-B.4 are the bcd value of the received dtmf. all go high when active
    dv VAR PORTB.0
    RCSTA = %00000000
    'TURN OFF THE SERIAL PORT IE USART AND USE SEROUT
    rs_Dout VAR PORTC.6
    GOTo prebegin
    '***** Interrupt Service Routine *****
    ' The ISR first saves the processor context, and then jumps to either the Timer1
    ' ISR, or the Receive Data ISR, depending on the Int. Flags.
    asm
    ISR
    ; Save processor context
    movf FSR, w ; Save the FSR in fsrsave
    movwf fsrsave
    ; Check interrupt flags to see which interrupt fired
    btfsc INTCON, INTF ; Else if Ext. Interrupt,
    goto DTMF_ISR ; Go to Ext. Int. ISR
    ; If an unknown interrupt fired, exit the ISR
    clrf INTCON
    goto End_ISR
    ; External Interrupt Service Routine
    ; The external int. ISR
    DTMF_ISR
    endasm
    'this routine gets the dtmf tones from line and stores them in buffer
    GOto GETDTMF
    instbintr:
    @ IF DEBUG_MODE
    serout rs_Dout,4,[32,"Hi thr",32]
    @ ENDIF
    asm
    bcf INTCON, INTF
    goto End_ISR
    End_ISR
    ; Restore processor context
    movf fsrsave, w ; Restore the previous FSR from fsrsave
    movwf FSR
    movf psave, w ; Restore the previous PCLATH from psave
    movwf PCLATH
    swapf ssave, w ; Restore the previous STATUS from ssave
    movwf STATUS
    swapf wsave, f ; Restore W from wsave without modifying
    swapf wsave, w ; the STATUS reg.
    ; Return from interrupt
    retfie
    endasm
    PREBEGIN: main
    @ IF DEBUG_MODE
    serout rs_Dout,4,["Program serial testing "]
    @ ENDIF
    GOTO PREBEGIN
    getdtmf:
    detTone = 0
    valDTMF = 0
    timer0_ofcnt = 0
    back:
    if dv = 1 then
    '-------------------------START TIMER 0--------------------------------
    option_reg.5 = 0
    INTCON.5 = 1 'START
    detTone = PORTB
    'Due to pin connection on the board the following code
    detTone = detTone >> 1
    tonebuf = detTone & $0f
    'lookup table for digits
    '1-9 <=> 1-9 , 0<=>a, .<=> B, # <=> C, A <=> D,B <=> E,C<=>F, D<=> 0
    'My digit equivalents 0-9 <=> 0-9, A-D <=> 10 to 13,. <=> 14, # <=>
    15
    lookup tonebuf, ["D",1,2,3,4,5,6,7,8,9,0,"*","#","A","B","C"], detTone
    valDTMF = 1
    if dv = 0 then done
    goto back
    done:
    INTCON.5 = 0
    timer0 = TMR0
    timer0 = 26 * timer0_ofcnt + timer0 * 103/1000
    @ IF DEBUG_MODE
    serout rs_Dout,4,["TMR1",#timer0,32,#timer0_ofcnt,32,"tt",detTon e,32]
    @ ENDIF
    TMR0= $00
    '----------store tone in buffer--------------
    bf(endDigit) = detTone
    @ IF DEBUG_MODE
    serout rs_Dout,4,["dit",#enddigit,32,#bf(endDigit),32]
    @ ENDIF
    endDigit = endDigit + 1
    valDTMF = 0
    if (endDigit > (buffLen-1)) then
    endindex2 = buffLen - 2
    enddigit = buffLen-1
    for i2 = 0 to endindex2 step 1
    j2 = i2+1
    bf(i2) = bf(j2)
    next i2
    goto instbintr
    urgent word in subject is due to my flustration of not being able to debug this since last few days and time deadline of project
    Jul 2009
    The interrupt problem seems to be solved.I guess it was due to large amount of code in interrupt
    I am new to picbasic environment.Can anyone please let me know about the programming styles that are used in pic basic, any link on RTOS for pic basic?
    Programming styles? Like the discussion here?
    http://www.picbasic.co.uk/forum/show...6150#post76150
    Or to indent or not to indent?
    RTOS...What do you have in mind?
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 19:52
  2. Problem with Interrupt on PIC18F4620 PORTB
    By rookie in forum Off Topic
    Last Post: - 22nd March 2007, 01:34
  3. Problem with PBP interrupt and Serin, please help
    By rgregor in forum mel PIC BASIC
    Last Post: - 22nd August 2006, 19:02
  4. Interrupt Problem
    Last Post: - 16th November 2005, 20:58
  5. Interrupt stack overflow problem with Resume {label}
    By Yuantu Huang in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2005, 01:17
