I2C optional label question
Results 1 to 11 of 11
    France
    Default I2C question
    Hi Melanie, still on board, super ! and working on Sunday time !
    Aratti .. sorry, I didn't see the word GOTO ...thanks ..
    It is clear for me, that the control and address parameters are confusing for me ...
    I understand from the example, this is used with Eprom familly
    Control parameter is the main address
    and
    address parametre is used to point to the address location in the Eprom !
    I use for long time I2C commands in the simple way like
    I2CWRITE DataPin,ClockPin,Control,{Address,}[Value{,Value...}]{,Label}
    example :
    datapin var PORTA.1
    clockpin var PORTA.2
    I2CWRITE datapin,clockpin,$C2,[11,22,33,44],errorI2C
    etc ...
    etc ...
    errorI2C:
    flash a led ....
    goto Main
    As I do not understand Control and address story, I always use this and It works
    with a lot of synthetisers (SP5055 familly)
    Now I decided to be more serious ! and check the frequency lock flag
    (bit 6 of the SP 5055 register)
    that why I try to READ like that
    flag var byte
    I2CREAD datapin,clockpin,$C3, [flag], errorI2C
    if flag.6 = 1 then continue
    continue:
    etc ...
    etc ...
    nb: $C2 or $C3 I am not sure, but I can check the good value ..
    thanks for your help
    You did not understand my post... don't use CONSTANTS but use VARIABLES with I2C commands....
    ControlByte var BYTE
    ControlByte=$C2
    I2CREAD datapin,clockpin,ControlByte, [flag], errorI2C
    France
    Talking I2C question
    Hello Melanie, morning ..
    Oupps ...I will trust you as usual
    I will test it today
    thanks
    France
    I got it !
    it works ..
    my error was the missing brackets on the I2CREAD command
    it seems that without the bracket the I2CREAD become a I2CWRITE !
    I try using address $C2 or using a constant ... same results
    thanks to everybody
    francois
    here is my HUGE code !
    '* Name : TX2300 avec 16F84 *
    ' Variable Definitions
    SCL var PORTA.4
    SDA var portA.3
    LOCKBYTE var byte
    I2CWRITE SDA,SCL,$C2,[$48,$F8,$AE,$FF],errorload
    LOCK:
    I2CREAD SDA,SCL,$C2,[lockbyte]
    Lcdout $FE, 1 ' Clear LCD screen
    pause 50
    lcdout "lock=", #lockbyte, " bit=", #lockbyte.6
    goto lock
    errorload:
    pause 50
    lcdout "error load "
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  3. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  4. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  5. 18F452 "Unknown Processor" errors
    By schwinn_rider in forum mel PIC BASIC Pro
    Last Post: - 27th April 2006, 04:56
