led matrix pic 16f84 and 4017 help me please
Results 1 to 16 of 16
    May 2009
    thank u Darrel Taylor for helping me,i have another quetion, i,m using proteus 7.5, for testing my project but it seems not working good is there any other programe to test projects?
    What would be wrong with doing it the old fashion way?
    A bread board, some wires and parts. Then the only thing
    to worry about maybe is some stray capacitance.
    Quote Originally Posted by Mus.me View Post
    . . . . . .my project but it seems not working good is there any other programe to test projects?
    Hello Mus.me,
    The " code snippet" you posted . . . is that all of it or is there more? I ask because you made no mention of TRISA or TRISB, and those registers tell the PIC to make the ports inputs or outputs, also check your data sheet for that PIC because most of this series have open collector outputs on PortA.4 . I do not see config statements or OSC Define either.
    May 2009
    Hello Mus.me,
    ok joe in know to how to config them i think
    define osc 4
    porta = 0
    trisa = 0
    portb = 0
    i did everythings but to debug in protues it doesnt work good ex: porta.0 isnt sending data out in proteus so im lookin if there is any other software like proteus to debug my code ,ICD doesnt include f84 and many PICs,i did pic simulator but i didnt understand it so proteus is easy but it seems not doing good job and very slow ,thank u joe for helping me ..
    Feb 2007
    define osc 4
    porta = 0
    trisa = 0
    portb = 0
    this as well:
    trisb = 0
    porta = %10010
    pulsout portb.0,150
    pause 10
    porta = %11001
    pulsout portb.0,150
    so on .......
    Maybe worth changing the 'pause 10' to 'pause 1' if your display is flickering.
    does your 4mhz crystal have 2 caps (18 - 22pf) between each leg and ground?
    not shown on your diagram.
    May 2009
    Quote Originally Posted by wellyboot View Post
    this as well:
    trisb = 0
    thank u wellyboot for explaining, and thanks everyone trying to help ,,, i will do it and i post the result ........
    Mar 2009
    Default 4017 problems
    hello to everbody...so i tried to play a little with a 5x7 dotmatrix and 4017 whitch is driving the columns, the problem is that when i power down my circuit and power it up the scroll is not starting from first colum, sometimes it does, but i must to reset circuit a several times there is no clear pattern for this and the leters start to mix up, eny idea how to solwe this???
    edited:
    I realized that I can use the free pin uC to reset 4017
    Last edited by xxxxxx; - 5th February 2011 at 00:44. Reason: I have become smarter
