serial to PIC
Results 1 to 23 of 23
Thread: serial to PIC
    Default Tesla
    I misread your post before...
     SERIN PORT?.?,N9600,[K],myVar
    IF myVar = 3 THEN gosomeplace or dosomething
    Send K and another value from the PC " K3 " for example.
    The PIC will wait for the "K". When the PIC receives a "K" the next character will be written to myVar.
    Jul 2009
    Hi..
    thank u alot I lik [Always wear safety glasses while programming]
    I forget to tell u I am new in PICBASIC PRO now only 2 weeks. I think the code will be like this:
    define osc 4
    include "bs2defs.bas"
    wait:
    SERIN PORTa.1,N9600,["K3"],myVar
    IF myVar = 3 THEN out
    out:
    HIGH PORTb.7
    PAUSE 300
    LOW PORTb.7
    goto wait
    but I cant understand [myvar]. How I can decide it???
    Thank u in advance.
    Jul 2009
    its not working
    May 2008
    Italy
    define osc 4
    wait:
    SERIN PORTa.1,N9600,["K"],myVar
    IF myVar = 51 THEN out ' Ascii 51 = decimal 3 (When you type 3 myvar will be 51)
    goto Wait ' this line is esential otherwise any key will activate the function
    out:
    HIGH PORTb.7
    PAUSE 300
    LOW PORTb.7
    goto wait
    This is the code that Dave suggested.
    From keyboard type K3 to activate portB.7 for 300 millisecs.
    Al.
    Jul 2009
    Now I am using windows hyper terminal to send serial signal. When I am sending [k] from it the terminal send it in ascii or in hex??
    I think send it in Ascii!!!
    so I have to send [k] or [k3]??
    and becuse I am new in PICBASIC PRO I can't understand how I can decide [myvar]
    Can u help ??
    Read the post from Al very carefully. He has everything there you need.
    Not sure what you mean by deciding "myVar". It is just a variable
    to store a value. The serin command will write data to that
    variable and the if/then part checks to see what the value is.
    Oh, the safety glasses thing. It is not a joke.
    Jul 2009
    Do you think this code will working fine??
    define osc 4
    wating:
    SERIN PORTa.1,N9600,["K"],b1
    IF b1 = 51 THEN out ' Ascii 51 = decimal 3 (When you type 3 myvar will be 51)
    goto wating ' this line is esential otherwise any key will activate the function
    out:
    HIGH PORTb.7
    PAUSE 300
    LOW PORTb.7
    goto wating
    I am using PIC16F84a and port RA! Connected to 22k ohm then to the pc serial port. And I am using windows hyper terminal to send the serial signal now my question number tow is what I have to send [k3] or [3] or[k] or 51???
    good glass:)
  1. PIC to PIC "wired" serial one-way communication - SERIN2/SEROUT2
    Last Post: - 14th April 2008, 21:02
  2. Automatic VB6 to pic serial connection
    By arniepj in forum Code Examples
    Last Post: - 10th January 2008, 08:57
  3. Serial Com Pic to Pic
    By uludere72 in forum mel PIC BASIC Pro
    Last Post: - 31st May 2005, 11:06
  4. Serial Pic to Pic using HSER
  5. Serial communication PIC to PIC help.
    Last Post: - 24th January 2005, 16:45
