IF...THEN inside a Loop
Results 1 to 11 of 11
    Jun 2009
    Sc*nthorpe, UK
    Hi Bill
    I do not think you are missing anything. The only thing I can see is that you should put parenthasis around you conditions when you use the AND statement but I can not see how that or why that would work with one chip and not another. I will read the data sheet on the PIC18F8722 but I am not hopeful. Generaly what I do in these cirumstances is to find a work round solution and then later on, some times years later, all becomes clear.
    What happens if X=1 ?
    Jan 2006
    Istanbul
    Also,
    IF X<1 THEN PORTB=$F0 is the same as X = 0
    IF X>1 AND X<3 THEN PORTB=$3C is the same as X = 2
    IF X>2 THEN PORTB=$0F is the same as X = 3 ( For loop goes to 3)
    Thus,
    IF X = 0 THEN PORTB=$F0
    IF X = 2 THEN PORTB=$3C
    IF X = 3 THEN PORTB=$0F
    looks better.
    Nov 2007
    South-West of Australia. A small town called Denmark. 'Where the forest meets the sea.'
    Default If...then
    Sorry - I made a silly mistake in the code I posted. The case where X=1 shows my error.
    However, the real code that was/is causing trouble was for a larger range of X and included '>=', '<='.
    My poor attempt to simplify the real problem failed!
    I'll tidy up the real code and post it soonest.
    Thanks for your input.
    Regards Bill legge
    Nov 2007
    Default PIC BASIC PRO LONG and IF..THEN
    Sorry for my earlier muddled post. I've done some more work on the problem and have pinned down my difficulty.
    I am compiling using PBPL and using a graphic LCD with 4 driver chips.
    The GLCD is 240 pixels wide and I need to activate the Chip Selects as the display sweeps along:
    0 to 63 CS1
    64 to 127 CS2
    128 to 191 CS3
    192 to 239 CS4
    The chip selects are connected to PORTB and my code is:
    clear
    DEFINE OSC 40	' Run on PIC18F8722, HSPPL
    ADCON1	= $0F	' Set PortA to digital
    TRISB=0               ' Make Port B outputs
    PORTB=0	             ' clear the port
    X	var	byte
    Loop:
    PORTB=$0
    for X = 0 to 239
    	if X<64 then PORTB=$01
    	if X>63 and X<128 then PORTB=$02
    	if X>127 and X<192 then PORTB=$04
    	if X>191 then PORTB=$08
    	pause 5
    next X
    goto Loop
    If I compile using PBP it works properly and the chip selects turn on/off as X goes from 0 to 239.
    If I compile using PBPL it does not work.
    I need to use the LONG compilation. Any idea what is going wrong?
    Regards Bill Legge
    Hi Bill,
    No idea what's wrong at this point.
    But I did run your program as is, no changes, on an 18F252.
    Works the same with either PBPW or PBPL.
    You can also do the same thing like this ...
    for X = 0 to 239
      PORTB = DCD (X >> 6)
      pause 5
    next X
    Added:
    So that it only affects those 4 pins, you could do this ...
    PORTB = (PORTB & $F0) | DCD (X >> 6)
    Silly question.
    PM or MPASM ?
    Or does it matter?
    Jul 2009
    Smile I think u can help
    I am new with PICBASIC
    I am trying to understand
    Good luck for all.
  1. Controlsystem for compact sporting (clay shooting)
    By Fredrick in forum mel PIC BASIC Pro
    Last Post: - 30th July 2009, 17:48
  2. Serin to Serin2 ??
    By Gixxer in forum mel PIC BASIC Pro
    Last Post: - 25th January 2008, 04:56
  3. Serial Relays
    By tazntex in forum General
    Last Post: - 17th May 2007, 18:42
  4. newbie Q - edge detection?
    By RMCRAVEN in forum mel PIC BASIC Pro
    Last Post: - 9th October 2006, 09:20
  5. Newbie question:
    By Izone in forum mel PIC BASIC
    Last Post: - 26th February 2006, 17:24
